R56 oil pan plug info
Old May 19, 2010 | 02:48 PM
miniinhd's Avatar
miniinhd
oil pan plug info
Hello Mini owners I'm trying to find out which should i use for oil pan plug removal torx-50 or a #8 allen wrench to remove the plug my car is 2008 MCS THANKS IN ADVANCE MINIINHD "KEEP MOVIN"
Old May 19, 2010 | 04:37 PM
Hawkeye's Avatar
Hawkeye
oil pan drain plug
While I can remember exactly, I think it is an 8mm allen wrench. My recommendation is to replace it with a drain plug that you can put a closed end wrench or socket on to (1) make it easlier to remove and (2), more importantly, less probability of stripping the OEM recessed hex plug. Just a thought...
Old May 19, 2010 | 04:49 PM
grodenglaive's Avatar
grodenglaive
I use a socket wrench with a hex bit - a must have if you want to torque it to spec. I hate that my socket wrench gets covered in oil when I remove the bolt though. Then it gets slippery and I usually end up dropping the whole wrench in the oil.
Replacing the drain plug sounds like a good idea.
Old May 19, 2010 | 05:59 PM
gasmini03's Avatar
gasmini03
Check out this thread for sizes.
https://www.northamericanmotoring.co...with-pics.html
Old May 19, 2010 | 09:10 PM
Benibiker's Avatar
Benibiker
Mine uses an 8mm allen. No need to tighten it like the whole car is held together by that bolt, just a little tighter than snug will work, that way it wont get stripped allen or bolt head...
Old May 20, 2010 | 03:01 PM
LittleJoe's Avatar
LittleJoe
I use the 8mm allen wrench to remove it. The allen wrench is easier to clean up once it gets oil all over it upon removal.
Old May 20, 2010 | 06:41 PM
///Mflossin's Avatar
///Mflossin
Mine was a T50 torx but I replaced that with a 17mm dimple plug
Etrain
16
Aug 5, 2024 04:37 AM
bobbiemartin
Jan 20, 2016 05:28 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
minipopkart
Aug 13, 2015 05:22 AM
