R56 Does the Mini use a separate A/C motor?
Handy
Sorry to burst your Bubble but cars have been doing this for decades. My Old 88 chevy did this.
So... My bubble is fine. Besides, I'm just an LsX tuner in a mini, no need to worry about my bubble :D
and to the OP: yes, the AC compressor causes drag on the serpentine system when engaged, which will lose you a few HP (not many, but still, when you're dealing with a mini, it's a few) but as said above the clutch that drives the AC will let go even with the AC on when you get into it hard.
and to the OP: yes, the AC compressor causes drag on the serpentine system when engaged, which will loose you a few HP (not many, but still, when you're dealing with a mini, it's a few) but as said above the clutch that drives the AC will let go even with the AC on when you get into it hard.
"Oh sweet so the AC will actually free up some power when it's on?"
I think you misunderstood. He said the A/C will use more power when it is on. If you start accelerating hard with the A/C on, however, the electronics will turn off the A/C compressor to free up power, temporarily, while you're accelerating.
No free lunches at the MINI lunch counter.
To answer the OP's question in a sideways manner, I always have the AC button on in my MINI (lots of humidity in Houston), and it's hardly noticeable. The AC compressors of today use much less power than those of 20 years ago when you could feel them kick in.
True dat.....
There's a substantial difference between my '03 and my '09 too.....
When the A/c was on on the '03 it felt like I was dragging a boat anchor till it got some boost up, on the '09 I hardly even notice it.
There are only a couple cars...hybirds that use a seperate motor to run the ac...and even this is a very recent devolpment...older hybirds would remain running, just to keep the ac on unless the heating/cooling was set to economy ( I have had the unfortunte experance of driving a few as "upgrades" for car rentals...if you view a car/driving as a way to get from point a to point b, and dislike the act of driving, it might be ok, but if you derive any pleasure/enjoyment from getting behind the wheel, they, in a word, suck).
Many makes/models for years have had the clutch on the ac disenguage for a while, like previouly said, under high load condition.
Dec 23, 2015 10:36 AM
