R56 Top 5 Mods
Old Feb 23, 2011 | 01:27 AM
  #26
Joey Mojo's Avatar
Joey Mojo
Handling:
-27mm front & 22mm rear sway bars w/ endlinks
-KW V1 Coilovers
-Vorshlag camber plates
-light, larger, wider wheels (17"x7.5)
-Control arms
Performance:
-Turbo back exhaust
-Front mount IC
-IC plumbing & blow-off valve
-access port w/ RMW tune
-Cold air intake of choice
Convenience:
-Valentine 1 hardwired above mirror
-powered sub-woofer linked to stock system
-smartphone vehicle mount
-iPod/bluetooth (a must for daily drivers!)
-Armrest w/ storage
Aesthetics:
-black out (windows, chrome trim, door handles, gas cap, joey-mod...)
-side scuttles of choice w/ l.e.d. blinker
-change exterior blinker and fog light bulbs (all xenon-white for me)
-gauges
-custom upholstery
Is there anyone who knows how to run video through the stock MINI navigation??
Old Feb 23, 2011 | 04:03 AM
  #27
claud's Avatar
claud
While I have been waiting for my Mini to be built and delivered(next week), I have bought a few minor mods. First I ordered a full set of good quality coco mats. Then I ordered a 4" antenna from Alta. First real mod will be Valentine 1 hard wire. After its been here a few months I'm going to order a set of Breyton wheels. Last this year before the end of the year it will be full JCW suspension.
Old Feb 23, 2011 | 10:03 AM
  #28
UGAClubby's Avatar
UGAClubby
I will be replacing the exhaust with a Borla Cat-back system, K&N CAI and the NM downpipes. What should I expect as far as performance? How will it effect boost? This is my first Turbo. Is my scanguage sufficient to monitor boost or do I need to look at something else?
Old Feb 23, 2011 | 01:21 PM
  #29
proj4ever's Avatar
proj4ever
Originally Posted by onefish2
How about driving the car first. And then figure out how many thousands of dollars you want to spend modifying your car. And then what do the modifications accomplish.
You have not driven the car yet. Do you want/need more power, braking power, handling etc.
I have done lots of mods to my car and I always think about doing more. I have a 09 JCW. Do i really need a downpipe? Or coilovers?
I would say drive the car for a few thousand miles and make small modifications over time.
There are tons of topics here on NAM with good advice and bad advice too.
+1
Never change more than one performance variable at a time!
Old Feb 23, 2011 | 09:29 PM
  #30
thevelourfog's Avatar
thevelourfog
Originally Posted by proj4ever
+1
I'd say to change multiple things at once if you'll save time and/or money on labor. For example, I would install an entire turbo back exhaust instead of doing it in pieces. Suspension too, since you usually need alignments after you do anything and labor is often the same price to install springs or springs + shocks + sways, ect.
May as well do it all at once, but in a perfect world, I'd agree that it would be ideal to do one thing at a time.
Old Feb 23, 2011 | 09:53 PM
  #31
vettestripes's Avatar
vettestripes
Originally Posted by JamesHunt
Try not to use products that are sold by a marketing company that uses the letter A twice in its name .
Man, I did not know this??? Why? Overpriced? Or not well engineered?
Old Feb 24, 2011 | 08:43 AM
  #32
mini on's Avatar
mini on
Mini makes a euro armrest that opens.
Old Feb 24, 2011 | 01:32 PM
  #33
reRESERVEDMD's Avatar
reRESERVEDMD
- Black out (Headlamp rings, mirror caps, grille, scuttles, gas cap, rear tail rings, bezel around the entire car)
- tint windows
- black out all 4 side markers
- john cooper works brake and gear handles and REAL leather boots
- drop
= perfect mini Ah and you can debage for free! Looks much nicer!
Old Mar 10, 2011 | 02:56 AM
  #34
Achilles honor's Avatar
Achilles honor
y do u say that?
Old Mar 10, 2011 | 05:32 AM
  #35
Helix13mini's Avatar
Helix13mini
1. Tune
2.
3. Rear Sway Bar
4. Good, non run-flat tires
5. Driving school
Old Mar 10, 2011 | 06:26 AM
  #36
LASRGUY's Avatar
LASRGUY
1. Oil catch can. Cheap and it should reduce carbon deposits on the intake 2. I'd suggest an Alta accessport ECU tuner next. It will noticeably increase power and you can download new ECU maps as you do additional mods. When you've upgraded the car a lot it might be worth getting a custom RMW tune for the Accessport.
3. nm springs and swaybar. If you plan to be a track rat maybe step up to coilovers but for a little lowering with a nice ride the nm springs are a good choice. If you plan to do camber plates, it would make sense to do them during the spring install.
4. Dos or DDM CAI
5. Turboback or catback depending on your bias for power vs loudness/drone
The brakes and tires can wait until you need to replace them anyway. When you change the tires, non-runflats will improve the ride. You can upgrade brake lines and rotors when you do the brakes.
Old Mar 10, 2011 | 12:27 PM
  #37
Joey Mojo's Avatar
Joey Mojo
Originally Posted by Helix13mini
1. Tune
2.
3. Rear Sway Bar
5. Driving school
Got all those except the first two. That is until they both come in delivery! Should be a good summer...
Old Mar 10, 2011 | 01:29 PM
  #38
ngweibing's Avatar
ngweibing
so many mods.. no monety to do all
Old Mar 10, 2011 | 03:50 PM
  #39
Achilles honor
This is gonna be my order.
1.tires/rims
2.dos intake
3.magnaflow exhaust system
4.intercooler
5.accessport (hopefully they'll have it for the '11 mcs by this time
I think this is a pretty good list
Old Mar 10, 2011 | 05:02 PM
  #40
bolar's Avatar
bolar
Back seat head rest mod. (removed the stop rings).
V1 hard wire.
Coco Mats.
Considering:
Boot stripes.
Wiring rear fogs with brake lights mod.
Would really like a short shifter.
Old Mar 12, 2011 | 01:12 PM
  #41
Kaanger's Avatar
Kaanger
Hello I am looking into getting a performance chip for my R56 mini. What would be the best choice for a reasonable price?
Old Mar 12, 2011 | 01:25 PM
  #42
phxsteele's Avatar
phxsteele
Alta Access Port.
Old Mar 12, 2011 | 01:34 PM
  #43
Kaanger's Avatar
Kaanger
Why is this one 900$ and some are 100$? What if I don't have that kind of money? What would be a better choice?
Old Mar 12, 2011 | 02:43 PM
  #44
phxsteele's Avatar
phxsteele
any chip/tune you see of 100 is a gimmick. Dont by/buy it. The accessport does cost a few bucks but it is well worth it, and when you decide to move on from the MINI brand you can sell it and recoup most of your money for it.
Old Mar 12, 2011 | 10:54 PM
  #45
Melangell's Avatar
Melangell
I love your list, Bolar!
Old Mar 13, 2011 | 04:48 AM
  #46
claud's Avatar
claud
Car arrived on the 2nd. I immediately pulled the pins and stops on the rear headrests and installed 4"Alta shorty antenna and coco mats. Since then I have ordered:
1. matching coco trunk mat
2. V1 hardwire kit(had to reorder--first was trashed by USPS)
3. 19 mm H-Sport rear bar (decided against JCW suspension)
4. NM torque arm insert
Old Mar 13, 2011 | 05:30 PM
  #47
bolar's Avatar
bolar
Thanks, if it ever gets nice again the first thing I'm going to do is claybar it and throw down some Zaino .
Old Mar 14, 2011 | 09:33 AM
  #48
thevelourfog
After having an auto loaner S for a week so far, tires would be definitely be #1. Stock run flats are horrible!
pewx3
29
Jan 15, 2016 11:14 AM
CaptKen
R59 :: Roadster Talk (2012+)
11
Oct 21, 2015 06:32 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
larryd96
11
Sep 8, 2015 05:01 AM
Gen1Parts
Sep 7, 2015 01:37 PM
