R56 Replacing Grill
Old Aug 25, 2009 | 03:29 PM
Nrob's Avatar
Nrob
Replacing Grill
I am going to replaces my justacooper's stock chrome grill with the JCW one from out motoring. I have been searching the forum for some instructions but all that I seem to find are threads about the lower grill. I am most worried because it is not pre cut. How hard is this? What tools will I need? Any one of pics of the install? If there is a thread, please point me in the right direction. Thanks.
Old Aug 25, 2009 | 03:42 PM
ron-s mini's Avatar
ron-s mini
Try this:
http://www.totehmoon.com/uploads/gri...uctions_v1.pdf
Old Aug 25, 2009 | 03:50 PM
Nrob's Avatar
Nrob
Thanks, that helped a bit, but it was for a S if that makes a difference. Also I wanted to see pics, or at least good directions about cutting the new grill.
Old Aug 25, 2009 | 05:54 PM
z06invb's Avatar
z06invb
Not sure what you mean about cutting the grille. I got a JCW grille for my Cooper and popped the reusable plastic rivets off the top of the grille and then it just snapped out. Placed the lower chrome trim on the JCW grille and snapped it back in replaced the plastic rivets and was done. it took about 10 minutes to complete.
Old Aug 25, 2009 | 07:13 PM
Kwilson's Avatar
Kwilson
you only need to cut the grill if you have driving lamps installed
Old Aug 25, 2009 | 07:24 PM
ron-s mini's Avatar
ron-s mini
Makes no difference (the bottom trim piece is different but the method is the same).
Old Aug 25, 2009 | 08:30 PM
mini cooper mini's Avatar
mini cooper mini
i did mine the first day i got it on a base model. It was SO simple and quick. PM me if you want me to call you and walk you through it
Old Aug 25, 2009 | 08:47 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
Open bonnet. Pull the 4 plastic 1/4" round plastic rivets/heads that are lined up across the flange of the grill as it connects to the cowl. Once those are out pull the lower grill trim straight outward and squeeze the four Giant clips/tabs along the bottom of the stock grill. Pull grill off completely and replace using existing hardware. Lower trim just clicks back into place. No hardware along the bottom, aside from the molded in clips that are part of the grill.....
Old Aug 25, 2009 | 09:00 PM
Nrob's Avatar
Nrob
Thanks. Sounds like it won't be to hard. I don't actually get my MINI until Saturday but the grill and antenna are defiantly going to be my first mods.
Old Aug 25, 2009 | 09:23 PM
rwwilsonjr's Avatar
rwwilsonjr
Here's a question. Will the standard Just a Cooper grille fit a R56 MCS?
Old Aug 26, 2009 | 01:09 PM
dangparker's Avatar
dangparker
Interested in the justa grill on the S also
I really do like the look of the crome grill on the Justa better than the black "S" grill.
Are the two interchangeable? Will the bigger grill slats effect performance/cooling?
Finally, has anybody ever done this and maybe...posibly(sp)...could provide pictures?
Cheers
Dan
Old Aug 26, 2009 | 01:11 PM
drewstermalloy's Avatar
drewstermalloy
When I bought my JCW grille for my non-S, someone with an S bought my chrome grille from me. I don't know if it ever fit though. I want to say the 2 grilles have different attachment points on the car.
Old Aug 26, 2009 | 02:27 PM
rwwilsonjr's Avatar
rwwilsonjr
Cheers
Dan
I've been interested in doing this too but evidently it isn't possible without much modification. I found this quote on Motoring File:
"The chrome grille doesn’t just clip on in place of the mesh grille on the Cooper S. The radiator support on the Cooper S extends further forward to accommodate the turbo. Because of that, the Cooper grille does not fit without extensive modification. Unless the Cooper D grille is different from the normal Cooper grille."
Old Aug 26, 2009 | 02:43 PM
Dinosaur's Avatar
Dinosaur
You might want to take a close look at the chrome grille, it may not be as "open" as you think, mine has only one slat open, the other two are not.
boostedhaze
Jan 2, 2018 07:26 PM
blackie
Jan 18, 2017 09:56 PM
dcrna1
Aug 19, 2015 01:30 PM
