R56 Funny Harmless Noise
Old Jun 18, 2009 | 06:41 PM
  #26
MotorMouth's Avatar
MotorMouth
Originally Posted by Xray'dit_Mini
My money would not be on the noise being the fuel pump, but rather a pneumatic locking system. I had a pneumatic locking system in my VW corrado, and it made the EXACT same noise at the EXACT same times.
just my $.02
Your 2 cents would be wrong.
IT IS THE FUEL PUMP.
Old Jun 19, 2009 | 10:34 AM
  #27
carsncars's Avatar
carsncars
+1
I looked at the gas cap locking pin while locking and unlocking and that isn't it. It only whirs when you unlock it after a little while sitting idle; if you unlock it (accompanied by a whir), then lock it, then unlock it, on the second unlock, it doesn't whir. Which supports the hypothesis that the fuel pump is the cause.
...in any case, there's way too much effort being put into this.
Old Jun 19, 2009 | 04:14 PM
  #28
coreygo's Avatar
coreygo
I have an interesting sound from my new MCS. It's more like crickets or whatever and I notice in some cases it goes away when I let off the gas and becomes more intense when I press on the gas. I kind of like it but I'm curious what it is. It gives the car personality, lol.
Old Jun 20, 2009 | 06:14 AM
  #29
Agent.COOPER's Avatar
Agent.COOPER
Originally Posted by Robin Casady
OK, I lied. It isn't the fuel pump pressurizing the system when you open the door. It is the Improbability Drive deciding between a sperm whale with roses, or a pot of gardenias surfing.
Oh, man. You seriously made me crack up laughing... I love you.
Of course, just in that 'that reference was awesome' sort of way.
Old Aug 3, 2009 | 06:46 AM
  #30
CThoma031's Avatar
CThoma031
Originally Posted by supertramp
speaking of noises... I'm hearing what sounds like a knocking or thumping noise coming from rear of my mini when I'm driving... It almost sounds like my bass thumping but even with the radio off I hear it. Its real random when it happens... Does anyone know what it could be?? Its an 09 mini justa cooper
I get the same noise and NOONE will actually answer what it is. Mine does it at low speeds that i can hear or when i turn it off it might do it a couple of times and I cant figure out what it is.
Old Aug 5, 2009 | 04:44 AM
  #31
ellinara's Avatar
ellinara
I have it 2 followed by a clicking noise... Could this be the doors being disarmed...
Old Aug 5, 2009 | 05:27 AM
  #32
investigator's Avatar
investigator
I will not believe it is the fuel pump until I get a Mini mechanic/tech at the dealership to confirm that. I understand that the R56 has a very high pressure pump because of direct injection. But when one opens the door the fuel pump starts????? Doubtful unless......................
Old Aug 5, 2009 | 05:42 AM
  #33
djam43's Avatar
djam43
The noise that you hear from the dash area is the motorised damper door in the ventilation system positioning itself .
Old Aug 5, 2009 | 06:39 AM
  #34
sequence's Avatar
sequence
Originally Posted by lacynpiper
I don't have the comfort access system so the fuel pump idea doesn't really answer what's going on in my car. Because of when it happens, I'm guessing that it has something to do with either the locks or the window motor. I don't mind the sound but I do want to make sure that this isn't a problem that should be addressed now before anything major happens.
Um, sweat not. RC and MM are right, it's the fuel pump pressurizing the DI system, and unlocking the car via the fob or confort access triggers it. All 2nd gen MINIs do this, inc mine and every R55 and R56 loaner Ive ever driven. Chill, man.
Old Aug 5, 2009 | 06:42 AM
  #35
sequence's Avatar
sequence
My money would not be on the noise being the fuel pump, but rather a pneumatic locking system. I had a pneumatic locking system in my VW corrado, and it made the EXACT same noise at the EXACT same times. just my $.02
Consider yrself .02 poorer
Old Aug 5, 2009 | 11:45 AM
  #36
tag's Avatar
tag
I get a giggling sound when I stomp on the gas. Anyone else get this?
Old Aug 5, 2009 | 11:50 AM
  #37
MINIdave's Avatar
MINIdave
No, I get a Wheeehoooo sound!
Sometimes followed by a Teeheee sound, and once in a while followed by an "Oh ***** sound" if I see red and blue lights in the rear view mirror.......
Old Aug 5, 2009 | 03:35 PM
  #38
Step's Avatar
Step
The noise you are hearing is your intank low pressure fuel pump pressurizing the system. The high pressure pump needs a decent amount of base pressure in order to reach the point where it wont miss on start up.
Old Aug 5, 2009 | 06:36 PM
  #39
Robin Casady's Avatar
Robin Casady
I hear that as well.
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
