R56 To RUN to or from Runflats?
Old Aug 4, 2008 | 01:04 PM
  #26
Robin Casady's Avatar
Robin Casady
Originally Posted by BlackS
Great!
Now, let the suggestions come in! I do not want to have to lower my car. I also do not want my new rims-tires to make the car look lifted so I have learned can happen with too much of an offset. 16" or 17" is fine with me. Any suggestions! I tend to like the clean look, maybe 5 stars or something. I am searching still.
Thanks everyone! This is a great forum to be in on.
I have both 16" and 17" wheels. Car came with 17x7" 22.5 lb. Crown Spokes. I replaced them with 16 lb. 17x7" CenterLine RPM. Good price, poor finish, and I found out later that the company got an F grade from the BBB for bad customer service. So, not recommended.
I was dissatisfied with the ride roughness of the 17" so I bought some Rota RB 16.6 lb. 16x7" wheels from a guy who bought them before he found out he couldn't use them for AutoX and keep the stock classification. I put 205/55-16 tires on them.
Ride was better, turn-in a little less responsive than the 17" but that may be the difference in tires as much as wheels. They are a little tedious to clean.
Two of them got damaged in an accident so I decided to replace them with Rota Slipstream 16x7" 14 lb. wheels that seem like they would be easier to clean.
At about the same time, I had the OEM brake pads removed and replaced them with Carbotech Bobcat 1521 pads. Since then I really haven't had much brake dust, so can't say if they really are easier to clean.
I like the 16x7 wheels with 205/55-16 tires. Although I'll probably try a different tire next time. I used Pirelli P-Zero Nero M&S (all season) because they were supposed to be quieter than the Michelin Pilot Exhalto PE2 205/45-17 on my other wheels. However, they aren't that much quieter and give up too much in grip, for my taste.
Rota wheels seem like they are well made and reasonably priced. I'm happy with them.
Old Aug 5, 2008 | 04:27 AM
  #27
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Originally Posted by MINIMotorMouth
2 months later I got a screw in a tire and had to replace the tire.
why would you replace a tire for a screw in it? Why not plug it?
Old Aug 5, 2008 | 05:49 AM
  #28
JudgeS's Avatar
JudgeS
I know this has been talked about often in here. B-U-T, I am thinking of getting some aftermarket wheels/tires. I keep reading of you all who have ditched the runflats. I have the bridge spoke runflat combo. I am thinking of bumping up to some after market 17's with all season performance tires maybe from tire rack.com.
Anyone have any insight on to do or not to do! Mostly because of looks do I want to do this. But, a softer ride would be nice to!
Well if you want a softer ride moving up to 17's (even with switching to non runflats) isn't going to accomplish that. To my surpirse I found the 16" runflats (conti all-seasons) to be way better than advertised, I also don't like giving up the security of runflats w/o a spare, no amount of slime or compressors are going to help that. I to eventually want to run summer wheels, and was originally going to go with 17's, but I'm thinking 16's now.
Wow Robin I love the Rota RB's so classic looking, to bad they got damaged. Any problems with rubbing with the wider tires?
Old Aug 5, 2008 | 05:50 AM
  #29
FLKeith's Avatar
FLKeith
Originally Posted by DaRKsMCs
WHERE CAN U GET SOME CHEAP SPARE TIRE FOR R56? 17" ...
There are Miata compact spares that have the same bolt pattern and are available on eBay. The center hole for the hub is slightly too small so needs to be enlarged with a file - this does not have to be very accurate as it is the bolts that locate the spare on the hub. The spare does not fit over the front brakes so you need to move a wheel from the back to the front if you get a flat at the front - this is also the case if you use a MINI compact spare.
Old Aug 5, 2008 | 06:28 AM
  #30
MINIMotorMouth's Avatar
MINIMotorMouth
I drove the tire to the dealer for repair. However, since the dealer is 75 miles from my home I drove further than the 50 miles allowed on a damaged runflat so they said they couldn't repair it-it had to be replaced. I guess I should have had the car towed-but I was relying on the fact that it was a run flat!
Old Aug 5, 2008 | 09:02 AM
  #31
JudgeS's Avatar
JudgeS
The dealer is always going to tell you to get it replaced even if it was 1 mile away (they are also going to charge you up the a$$ for it), in this case though you did have to have it replaced (driving 75 miles on it). If you would have driven to a local tire shop, it probably could have simply been patched/plugged depending on where it went in. Runflats can be patched/plugged (as long as they are not driven on for to long) despite what the dealer tells you.
Kimolaoha
Dec 5, 2020 09:32 PM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Tektura
Tires, Wheels, & Brakes
18
Sep 13, 2015 10:00 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
