R56 Coolant System Drain
Old Apr 25, 2008 | 05:10 AM
lwilliamson's Avatar
lwilliamson
Does anybody know if their is a drain on the Radiator/Coolant system anywhere that is easily accessible? I have looked but can't seem to find one. How do you drain the coolant to replace it?
Lyn
Old Apr 25, 2008 | 06:00 AM
ZIG's Avatar
ZIG
I am pretty sure the owners manual states the coolant is good for the life of the vehicle, which means you don't have to change it. I don't have my manual with me right now, but I remember reading that.
Old Apr 25, 2008 | 06:06 AM
DanF's Avatar
DanF
This is even worse than changing your oil every 25,000 miles.
Old Apr 25, 2008 | 07:31 AM
uzun's Avatar
uzun
Yes, the lifetime coolant is a joke!
Old Apr 25, 2008 | 08:34 AM
VelvetFoot's Avatar
VelvetFoot
My VW's coolant looked perfect after 100k miles.
Old Apr 25, 2008 | 10:07 AM
djam43's Avatar
djam43
It is NOT lifetime coolant. Mini recommends changing coolant every 4 years (maint schedule II). see owners lounge. The radiator has to have a drain on it, but you would have to remove a cover. I hear that the ZEREX 5 coolant is approved by BMW. What you are referring to is probably the trans fluid.
Old Apr 25, 2008 | 10:19 AM
DOT191's Avatar
DOT191
We have both the Cooling System & Brakes Flushed every 2 Years on our 2003
MC.
Old Jun 3, 2010 | 04:52 AM
fnc's Avatar
fnc
This is an old topic. I thought I saw something yesterday about draining coolant. It's not hard to drain and fill, but bleeding is different. I found this helpful. How to bleed cooling system, MINI Cooper R56 N12 Engine https://wiki.bentleypublishers.com/x/AoByAg
Old Jun 4, 2010 | 01:58 PM
bagwell's Avatar
bagwell
so where is there thermostat located?
NM, found it and the bleed air screw.
Old Jun 5, 2010 | 02:00 PM
countryboyshane's Avatar
countryboyshane
Right here
http://www.realoem.com/bmw/showparts...31&hg=11&fg=35
This also shows the vent screw is located next to the coolant temp sensor.
Kimolaoha
Jul 5, 2023 01:04 PM
theateist
Jul 2, 2017 02:21 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Gipper
Aug 8, 2015 05:39 AM
