R56 Front License Plate Mounting
Old Apr 9, 2008 | 05:42 PM
  #26
Robin81's Avatar
Robin81
I'm thinking about getting the no holes bracket for my mini, but I'm not really an install-it-yourself type person. Especially when it comes to cars. They make me very nervous. Is this something that's easy for a clueless person to install? Or should I just forget it and have my dealer drill holes?
Old Apr 9, 2008 | 05:49 PM
  #27
rrcaniglia's Avatar
rrcaniglia
ROBIN!! Don't drill. If you can pop popcorn, you can install this bracket. I'm not kidding. You pop the plastic cap off the tow hook site with a screwdriver. It comes right off. Screw in the mounting bolt. It tightens easily with a crescent wrench.
Attach the cross piece with one large bolt. Tighten it.
Attach two thin vertical strips of metal with one bolt and nut each.
Attch the license plate with the last four bolts and nuts like you would on an American car.
Trust yourself. You can do this.
R
Old Apr 10, 2008 | 05:51 AM
  #28
lhoboy's Avatar
lhoboy
Originally Posted by BMBULBE
I'd skip the front plate entirely. I've been driving without one for over a year without any "comment" from Chicago's finest.
I felt the same way for 3 years here in Marland until Smokey got me. Now I'm using the Gominigo set-up.
Old Apr 10, 2008 | 05:54 AM
  #29
lhoboy's Avatar
lhoboy
Originally Posted by gokartride
I tend to favor hiding the bumper seams and dimples on the R56 bumper...it's pretty odd to me to mount the plate elsewhere when you and everybody else can always tell where the plate is supposed to be. I insisted that the dealer drill and install that plate holder!!! I honestly don't get the angst about not putting the plate where it naturally (and often legally) belongs on R56, but to each their own. Just because I don't get it doesn't make it wrong.
Live a little! Learn to color outside the lines.
Old Apr 10, 2008 | 11:56 AM
  #30
Robin81's Avatar
Robin81
R
Well, my license plates came yesterday, so I figured I'd better make a decision. So... I bought the bracket from gominigo. It sounds like I can probably install it myself. And if I fail miserably, I'll just call in a favor from a guy I work with.
Old Apr 10, 2008 | 01:46 PM
  #31
gokartride's Avatar
gokartride
Can be done, but often yields unsatisfactory results.
Old Apr 10, 2008 | 02:11 PM
  #32
russr's Avatar
russr
Robin, I was in your same position...didn't want them to drill and wasn't sure about the no holes bracket from gominigo. I ended up just not putting on anything. I've been meaning to buy the gominigo one and see what it was like. Let us know once you install it and take some pics please.
Old Apr 13, 2008 | 12:55 AM
  #33
rippymcs's Avatar
rippymcs
I opted for drilling the bumper mainly bcause I'm using the plate and the holder as a barrier for one of 'em parking lot bumps. All the cars I have owned had the front bumper bumped by another car, one of them cracked the holder, another one put an egg size dent in the plate. There were many other occassions where I had to bend the plate back to it's original shape. I also have a 1/8" thick rubber sheet between the holder and the bumper, to cushion the blow. And to think I was playing safe by not pulling all the way into the parking spot, but in reality most drivers don't use the lines on the ground as a guide, they use the car in the space across from them as a guide, and they always miss.
About the dimples where you're supposed to drill the holes, on mine it is off-centered by about 3 mm. I realized that after I had drill the holes already.
Old Apr 13, 2008 | 04:56 PM
  #34
rrcaniglia's Avatar
rrcaniglia
Here's my plate. I like it. Robin, I hope you like your results.
Attached Thumbnails Front License Plate Mounting-nebraska-plate-001-medium-.jpg
Old Apr 13, 2008 | 06:32 PM
  #35
Robin81's Avatar
Robin81
Looks good! Mine's on its way, so I should have a report soon...
Old Apr 13, 2008 | 10:57 PM
  #36
wdavidhicks's Avatar
wdavidhicks
I can't remember why I needed to buy a 19mm combination wrench over ten years ago... Glad I still had it.
Old Apr 26, 2008 | 10:54 AM
  #37
FP's Avatar
FP
Finally an option for a centered front plate.
http://www.skenedesign.com/FPBracket/index.htm
Old Apr 26, 2008 | 11:09 AM
  #38
gokartride's Avatar
gokartride
An elegant solution!! It's nice to have options.
Old Apr 26, 2008 | 11:11 AM
  #39
Robin Casady's Avatar
Robin Casady
I don't see anything on there about it fitting a MINI.
I have the GoMiniGo bracket. It is all stainless steel and works well. Here are some photos:
The port with cover:
The port open:
Stainless steel stud for braket:
Bracket:
Old Apr 26, 2008 | 02:00 PM
  #40
FP's Avatar
FP
Sure it is. It's the short model. Look under Mini. And it's centered.
Old Apr 26, 2008 | 02:18 PM
  #41
porifera's Avatar
porifera
Not sure if it has been updated since you looked at it, but currently under car/bracket model it shows:
MINI
Cooper............................................ .........................................Short
Cooper S................................................. ................................Short
Cooper S Convertible....................................... .....................Short
John Cooper Works............................................. ..................Short
Looks interesting. I'd like to see more pics!
Old Apr 26, 2008 | 05:19 PM
  #42
rippymcs's Avatar
rippymcs
That's a great alternative. I thought about making something similar myself but was too lazy to do so.
Old Apr 29, 2008 | 04:37 PM
  #43
Robin81's Avatar
Robin81
Ok, so I tried installing the gominigo bracket over the weekend, and was relatively successful. It's on the car... mostly right. I have pictures, but they're still on the camera.
I have 2 questions before I go and try to fix it:
1) What is a lock washer and how do I use it?
2) How do you get a socket wrench to work the other way? Mine would only loosen the bolt, which did me no good at all.
It wasn't quite as easy as popping popcorn, but I got it done. Mostly.
Old Apr 29, 2008 | 04:45 PM
  #44
gregdconsulting's Avatar
gregdconsulting
A lock washer is a round piece of metal with a hole in the center. There are different varieties some look like a star and others are a circle with a cut in them. I think the gominigo bracket has the one with the cut, also known as a spit washer. You put the washer on the bolt before you tighten the nut. It is to keep the nut from loosening.
Socket wrenches can work to tighten or loosen. You either flip a lever on the head of the ratchet or you twist the ****. Both are on the opposite side of where you attach the socket. For the twist variety I think you have to hold the socket so it doesn't spin when you change the direction.
I hope that can help. The gominigo instructions should list the order you install parts, so the washer should be listed.
Greg
Old Apr 29, 2008 | 09:36 PM
  #45
Robin81's Avatar
Robin81
Ok, the lock washer is the one in the middle. What are the other two? Do I use them anywhere? Are they part of the lock washer?
And thanks to help here, I got the socket wrench working. Woo!
Old Apr 29, 2008 | 10:14 PM
  #46
mini-rolls's Avatar
mini-rolls
The Flat Washers; two out side ones are provided to allow you move the bracket out. They go on the bolt after the bracket is installed if you need to move the backet further away from the car.
The Lock Washer; middle one. Goes on the bolt before it goes into the bracket and when it is tightened down it will flatten out and prevent the bolt from backing out.
As far the rachet goes there should be a tab or gear on the back of the head that rotates to allow the rachet to tighten in the other direction.
Old Apr 30, 2008 | 10:24 AM
  #47
russr's Avatar
russr
Hey Robin81, I just got my gominigo license plate bracket. What tools did you use to install it?
Old Apr 30, 2008 | 11:23 AM
  #48
Robin81's Avatar
Robin81
I had a flat screwdriver to take off the little piece on the bumper. I had a 19 mm socket wrench to tighten the big bolt. I had a small wrench (I'm not sure what size) and a little screwdriver-like-thing that was shaped like an L to do the screws and nuts that actually hold the license plate in place. Pretty much, I just used the tools listed on the instruction sheet. Luckily, my roommate got a 160 piece toolkit awhile back, so I just tested things til they worked.
Old Apr 30, 2008 | 12:04 PM
  #49
Bernard_1962's Avatar
Bernard_1962
. . .is there any difference between the GoMiniGo no-hole license plate bracket and the one available from MOSS Mini?
(I have a 10% off promo from MOSS Mini)
I have a Clubman coming soon, should be finished with production tomorrow.
Old Apr 30, 2008 | 12:42 PM
  #50
mauberley's Avatar
mauberley
If I'm not mistaken, the GoMiniGo bracket uses stainless steel whereas the Moss bracket does not. I've seen pics of Moss brackets where there's some rust going on. Other than that... well, the GoMiniGo bracket has five height positions while the Moss bracket only has three.
