R56 washer fluid
Old Mar 26, 2008 | 07:29 PM
corin.mcblide's Avatar
corin.mcblide
washer fluid
So today I hit the window cleaner cause of all them damn bugs hitting my car and I get a warning that my washer fluid is apparently low. I have only had my MINI for 8 months and don't often use the washer. Anyone else with this problem? Can I buy any ol' washer fluid from my local pep boys and just plop it in there? or should i go to mini and get it done?
Old Mar 26, 2008 | 07:32 PM
sailorliz23's Avatar
sailorliz23
hehe i wouldnt say it running out is a problem. but yes bugs are very difficult to keep off the dang windshield. but to answer your question yes you can put any washer fluid you want. the only difference is that the one from the dealer has some alcohol stuff in it to keep it from freezing. i live in Miami so i definately dont need it. i guess if you live very close to the dealer and need other things than go to them otherwise just buy the one from pepboys
Old Mar 26, 2008 | 07:35 PM
corin.mcblide
thanks. yeah i'm in so-cal so i doubt freezing will be a problem. any recommendations?
Old Mar 26, 2008 | 07:38 PM
sailorliz23
i use the rainx one. it rains here ALOT so it helps with that. it also helps with visibility because our wipers are kinda bad. if you have the xenons though (like i do) it kinda gets wasted because you dont really need rainx there. just dont get the cheapest one with the scent because then you have to smell that junk every time you use your wipers. hope i helped
drrigg
May 27, 2022 03:31 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
schr5530
Oct 1, 2015 05:11 PM
