R56 Flash Blinking Three Times
Old Mar 9, 2008 | 06:17 AM
genik's Avatar
genik
Trying to make the flash indicator blink 3 times after one click, but cant. I follow the instructions as said on the manual, but cant find the flash indicator logo on the display. All only the time and date logos show up, after pressing the flash indicator leaver and nothing else! What im i doing wrong?
Old Mar 9, 2008 | 07:06 AM
rockridge's Avatar
rockridge
Did you have the ignition on? with the ignition off, mine displays a similar abbreviated menu like you mention. Press the start button, but don't push in the clutch. You don't want the car running when you do the changes.
Beebe's Avatar
Beebe
On my car ('07 MCSa) you have to start the car and leave it in park. Go to set/info and then scroll to the icon with the little key with the check mark. Then, scroll through that menu (locks, headlights etc) until you get to the one that says 1x and 3x click to highlight the 3x and then leave it. The menu will go away and your car will be set. I think you have to do this with each key fob individually?
Old Mar 9, 2008 | 08:58 AM
e30r56's Avatar
e30r56
Car can be running or off, as long as the ignition is in the ON position (all gauges active) and the car is stopped. Then follow T-POD's instructions.
Dec 23, 2015 10:36 AM
bjcarter2
Aug 31, 2015 04:03 PM
dscott90000
Aug 21, 2015 07:07 PM
M7Speed
Aug 14, 2015 01:50 PM
