R56 10-30w vs 5-30w
Old Feb 1, 2008 | 11:47 AM
EENY's Avatar
EENY
10-30w vs 5-30w
I noticed I last changed my oil using Mobil 1 10-30, not 5-30 as mfr recommended. I live in CA, so don't have subzero issues, but still, is this a cause for concern or not?
Doh !
Old Feb 1, 2008 | 12:30 PM
Rastven's Avatar
Rastven
Probably not but if you are worried you could always just drain the oil without replacing the filter and refill with recommended weight oil.
Old Feb 1, 2008 | 01:55 PM
PistWalrus's Avatar
PistWalrus
You will be just fine. There is not a big enough difference between the two weights to worry about it.
Old Feb 1, 2008 | 02:50 PM
johne123's Avatar
johne123
Good thing you're in California without the freezing temps. The first number refers to how the oil behaves in cold temps. The last thing you want is thicker oil in cold climates. Also keep in mind that both those weights of mobil 1 don't meet the same specs as the BMW/Mini 5w30. Specifically they don't meet ACEA A3. 0w40 Mobil 1 does however.
Old Feb 1, 2008 | 03:10 PM
NashvilleMiniStan's Avatar
NashvilleMiniStan
You're be fine. Just keep it clean.
jay80424
May 1, 2016 08:53 PM
Deluded
May 15, 2013 11:39 AM
Benibiker
May 26, 2011 08:03 AM
