R56 Sun shade creep
Old Jul 4, 2008 | 08:59 AM
  #26
e30r56's Avatar
e30r56
Yes, there is a TSB out there for the fix. Also, I had an 08 loaner and I could tell it had friction stops for when it was fully closed, very nice. The number is M540407.
SI M54 04 07
Special Roofs November 2007
Technical Service SUBJECT
Sunroof Sunshade Opens Spontaneously MODEL
R56 (Cooper and Cooper S) equipped with the Panoramic Sunroof (option 403) and produced up to 10/2007 SITUATION
While driving with the sunroof sunshades in the fully closed position, one or both of the shades may begin to creep open. This movement typically occurs under heavy acceleration, heavy braking, or when driving over a rough surface. CAUSE
Insufficient friction between the roller blind and the guide rail in the sunroof cassette. CORRECTION
Replace the end stop bumpers in the cassette with updated parts and modify the roller blind if necessary. PROCEDURE
1. Fully open both the sunroof and the affected roller blind.
2. Insert a flathead screwdriver (1) under the end of the guide rail (2) and rotate it to expose the end of the bumper (3). Press the bumper (3) out of the end of the rail.
3. Insert the new bumper (1) and press the guide rail down on to the cassette until it clicks into place. 4. Repeat this operation for the opposite side of the sunroof guide rail and if necessary, for the other roller blind. 5. Retest the operation of the roller blind. If the roller blind continues to open spontaneously, continue with the following procedure. 6. Remove the affected roller blind per repair instruction RA 54 13 115 (Front) or RA 54 13 120 (Rear).
7. Unroll 13cm from the front of the roller blind. Gently roll both springs backwards around a large dowel or something similar to relieve the spring tension from this part of the roller blind. When released, this 13cm section of the roller blind should be essentially flat. 8. Install the roller blind and verify that the problem has been eliminated.
PARTS INFORMATION
WARRANTY INFORMATION
Covered under the terms of the MINI New Vehicle Limited Warranty. Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Defect Code 54 12 05 37 00
Info is from Alldata.
Old Apr 10, 2009 | 12:00 PM
  #27
LOP's Avatar
LOP
No more creeping...it only took me a year to get it back to dealer to get fixed.
Old Mar 9, 2015 | 03:44 PM
  #28
Rebecca Marvel's Avatar
Rebecca Marvel
Photos?
For some reason the photos of this procedure are not loading.. is there anyway I can see the photos?
I'm having the creeping sun shade problem. LOL
Rebecca
Old Mar 11, 2015 | 09:18 AM
  #29
54107213811 Looks like the part right here for the newer buffer , don't have a picture yet. Looks like only for 2007 and some 2008 models R56 w/ sunroof.
http://www.ecstuning.com/Search/SiteSearch/54107213811/
#10 in the picture and small box diagram
USNAE2
16
Jun 17, 2022 07:17 AM
Lex2008
How to
47
Jun 15, 2022 06:18 AM
RobbyD
Jan 29, 2019 01:22 PM
Giants9595
Sep 29, 2015 10:49 PM
Accessory Products
Sep 10, 2015 11:38 AM
