R56 Low Pressure Tire Warning System
Old Nov 13, 2007 | 01:30 PM
  #26
Robin Casady's Avatar
Robin Casady
Originally Posted by obscurity
I don't have my car yet but according to the MA if you have a NAV system it will tell you which tire is flat but if you don't it will just tell you that a tire is low (but not which one)
That agrees with what someone with the system posted. IIRC, he has a NAV and posted a shot of the screen showing which tire was low.
Old Nov 13, 2007 | 01:55 PM
  #27
Rastven's Avatar
Rastven
Originally Posted by ghosthound
from what i understand, even the new system has no way of telling you the pressure in each tire... correct?
i would think that this would be possible since my dads 04 caddy has direct pressure monitoring and can tell you the pressure in each tire on the OBC.
It doesn't seem to show which tire unless you have the NAV. In my case I had a deviation of all 4 tires from the previous set point and that triggered the warning.
Old Nov 13, 2007 | 05:41 PM
  #28
TheOfficeMaven's Avatar
TheOfficeMaven
That would be me.
Here's the picture if anyone's interested in seeing it:
Old Nov 13, 2007 | 06:40 PM
  #29
Rastven's Avatar
Rastven
If they had bothered to tell me neato stuff like that was included in the NAV I might have sprung for it.
Old Nov 13, 2007 | 06:46 PM
  #30
Robin Casady
Originally Posted by TheOfficeMaven
That would be me.
Thanks. What does it look like when a tire is low? A red X through one tire, or something? If you'd go put a knife through one of your tires...
Old Nov 13, 2007 | 07:15 PM
  #31
TheOfficeMaven
Alas, I don't know as I haven't seen the sensor go off yet. I keep meaning to go out and let some air out of one of the tires just to see what happens, but I never seem to find the time. I'll try it this weekend (before some kid with a pen knife beats me to it ).
Old Nov 13, 2007 | 07:28 PM
  #32
russr's Avatar
russr
So on a Mini with the active TPMS but no nav, it won't tell you which tire on the OBC?
Old Nov 13, 2007 | 09:09 PM
  #33
Minidrivr's Avatar
Minidrivr
Originally Posted by Robin Casady
Check page 142 of your manual. For 17" it recommends 36 psi., unless you are travelling over 100 mph with four passengers & luggage. Then use 41 psi.
Now check the sticker in the driver-side door sill. My MCS (came with 17" wheels) says 38 psi.
Only 16" get a 33 psi recommendation, and that is for 195 tires. Wider 16" need more air.
Mine has 2 stickers in the door indicating tire pressure, 38 psi on one, and 41 psi on the other.
Old Nov 13, 2007 | 09:40 PM
  #34
Robin Casady
One of them thinks you will be travelling 100+ mph with four people and luggage. Did you buy your MINI in Germany?
Old Nov 14, 2007 | 05:31 AM
  #35
obscurity's Avatar
obscurity
Believe me it was tempting but in the end, for me, it would have been $2000 for a tire gauge since 99% of my time is spent on rfoads I already know pretty well.
Old Nov 14, 2007 | 09:34 AM
  #36
Robin Casady
More impressive than a flat tire graphic is the Park Distance Control graphic. It shows you how close the car is to obstructions. Then there is the listing of tracks on an audio CD (mp3 or AIFF) so you can navigate and select one. If you have iPod Integration, the NAV makes it easier to navigate it as well. Then there is the bluetooh phone management...
While the tire graphic looks cool, it only tells you which tire is low, not how low. If it was accurate to the 1/2 lb and displayed pressure for each tire it would eliminate the need for a tire gauge. Unfortunately, we still need to have and use a tire gauge.
Kimolaoha
Jul 5, 2023 01:04 PM
JamJam43087
Aug 16, 2015 02:02 PM
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
