R56 Brake Warning
Old Nov 7, 2007 | 11:01 AM
sp_clark's Avatar
sp_clark
Brake Warning
I've been getting this warning (attached) for about three weeks now. Manual is pretty vague about what it means; I have a dealer appointment this coming Monday.
Do I need new brake pads already? Are the stock R56 pads as soft & wear-prone as those on the R53 I had before?
Old Nov 7, 2007 | 11:14 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Could be related to this:
https://www.northamericanmotoring.co...d.php?t=110574
Try your turn signals and wipers.
Do you know there is a forum for problems?
https://www.northamericanmotoring.co...play.php?f=188
Old Nov 7, 2007 | 12:53 PM
johnnosek's Avatar
johnnosek
Your brake fluid is low
Old Nov 7, 2007 | 01:43 PM
sp_clark's Avatar
sp_clark
Problem? Didn't Think It a Problem 'till Now!
They work fine, thanks.
Yes, but I didn't think this a 'problem'... until now.
Old Nov 7, 2007 | 01:44 PM
djam43's Avatar
djam43
Bring it back to the dealer they will install a new module under warrenty. it is a known prob. got mine fixed today.
Old Nov 7, 2007 | 02:08 PM
sp_clark's Avatar
sp_clark
What's "Low"?
The fluid reservoir is in common with that for the clutch, right?
I finally located it (under the hatch panel just in front of the wiper rest); fluid looks to be about 1/4" to the low side, if the ridge inside the reservoir is an indication of where it Should Be....
If it's a "known problem" Hopefully the dealer will have the correct replacement module on hand (spoken of below) when I arrive next Monday morning.
Old Nov 7, 2007 | 03:54 PM
daffodildeb's Avatar
daffodildeb
I don't think this is the SZL. You have an actual brake warning--fluid, etc. The SZL gives you an idiot light for the PARKING brake.
Old Nov 8, 2007 | 08:08 AM
TrboKrt's Avatar
TrboKrt
I have been getting these warnings randomly but have been increasing the last couple days.
I checked my brake fluid last night and it was indeed at the MIN level. Filled to the MAX level and today (so far) no more warning lights/gongs/flashings.
Old Nov 8, 2007 | 08:39 AM
MIN 18's Avatar
MIN 18
welcome to the club! you have the ateering angle sensor problem. My car was exported to the Philippines and I've had this problem for 6 months now. No MINI dealer here to help me....
UncDeo
Nov 4, 2019 04:08 AM
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
