R56 Solution for Mesh Sun Screen?
Old Nov 8, 2007 | 02:36 AM
  #26
Krut's Avatar
Krut
Originally Posted by LynnEl
If tint reflected heat, the glass would be cooler, not hotter. So this argument makes even less sense. Virtually every office building I have ever seen has tinted glass windows. Again, the cracking argument makes no sense at all. Do realize how hot safety glass has to get to break??
But most office windows don't have vinyl tint either. They have manufactured tint in the window.
Swerving this back on topic - if anyone has a tint contact (Solar Solutions) can you please give a call and find out if tint on the INSIDE can cause cracking?
Old Nov 8, 2007 | 04:35 AM
  #27
nlscooby's Avatar
nlscooby
Cracking is an urban legend. Any place that refuses to tint a sunroof has no idea what they are talking about. After extensive searches I have found not one first person case of tint causing a sunroof to crack. There is no logic to it. Since the sun is just as likely to beat down directly on side windows as the sunroof, there is no logic to the argument. .
I have never seen automotive glass crack...due to tint = I simply communicated that the manufacturers and installers of residential windows have denied warranty claims because the glass was tinted with a reflective coating....which Increases the surface temperature of the glass.
Lynn - you're insistance that there "is no logic to it" is humorous. There IS logic. Someone else explained it: tint is applied to the inside of the glass, which then has a multipier effect. The argument that the sun is just as likely to beat directly on the side windows is also false. Take a look at vehicle paint fade......same paint, same material,but the hood, roof and trunk of a car will ALWAYS fade faster than the sides of a vehicle.
Old Nov 8, 2007 | 04:18 PM
  #28
BrandonH's Avatar
BrandonH
Originally Posted by pdoyle
I live with the Texas sun which is also brutal. I have a 5% Limo Tint on my sun roof and it made a huge difference!
If anyone living in Houston wants their sunroof tinted at 15% to 0% call Josh at Cut Above on Hwy 3. His number is 281-216-7087. He is the guy who did my tint and he gladly does it.
Old Nov 8, 2007 | 05:23 PM
  #29
dwdyer's Avatar
dwdyer
Originally Posted by The QZ
I don't understand how putting some plastic on the glass will make it crack, and I haven't heard of anyone that has had it crack.
It's not the film, it's the heat.
Glass usually contains some amount of nickel sulfide as a consequence of the manufacturing process. Over time, these inclusions rearrange from an amorphous to a crystalline state, making the glass more brittle. Heat accelerates this. Spontaneous shattering has been known to happen.
http://en.wikipedia.org/wiki/Nickel_sulfide_inclusion
The sunroof is exposed to much more heat than side-windows, and a dark tint absorbs the heat. Some who have tinted sunroofs recommend (relatively) reflective tint to help avoid that.
Old Jan 6, 2008 | 06:04 AM
  #30
umberto's Avatar
umberto
from Jimmieshear:
Agreed, back to the original topic.. .
I only found this ... https://www.northamericanmotoring.com...d.php?t=106833
Got me where that product is or how it's development is going.
....I started that thread about my fix for the sunroof glare/heat in the 2002-2006 models (mine is an '04 MC ).....still works wonderfully for me, but alas, no luck, as yet, getting it produced. I sat in a 2007 at the dealer and I think the mesh screen and frame sits closer to the glass so there is less space for my shade with its brackets to fit....can anyone confirm that the 2007-2008 has less of a gap betwwen the glass and mesh compared to the 2002-2006 model years?
Old Jan 6, 2008 | 06:08 AM
  #31
tdm156's Avatar
tdm156
Ruling the curves
I have the http://www.stratmosphere.com/mini_interior.htm shade and it has worked great and will probably be getting another one for our 08 when we take delivery.
Old Jan 6, 2008 | 06:16 AM
  #32
LOP's Avatar
LOP
I sent the OP a PM, but we had the sun roof tinted with limo black and you can still enjoy the sun without the glare or heat. Money well spent
USNAE2
16
Jun 17, 2022 07:17 AM
rikaro
Nov 24, 2015 02:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
Giants9595
Sep 29, 2015 10:49 PM
