R56 Oil Changed! DIY
Old Oct 24, 2007 | 06:57 PM
  #76
jascooper's Avatar
jascooper
Originally Posted by r56mini
The space shuttle gets an oil change after every launch. Why should we not change the oil every 7000 miles? Beat that!
Space shuttle goes a lot farther than 7000 miles between changes...
Old Oct 25, 2007 | 08:16 AM
  #77
eeterp's Avatar
eeterp
Old Oct 25, 2007 | 11:39 AM
  #78
ubdylan's Avatar
ubdylan
Originally Posted by steveng
Besides I happen to one of those 07 MCS with the noisy engine. Sounds like a diesel.
Dude, was that "diesel" noise there when you drove the car off the lot? If it's something new, you probably need to add some oil. Have you checked the dipstick lately. When you leave the oil in this long (factory changes only), you are bound to burn some. Depends on the driving and your mileage, but yes, you could be low on oil.
Old Oct 25, 2007 | 11:45 AM
  #79
steveng's Avatar
steveng
Hi,
Oil level is full and oil is clean. I only have 2,400 miles on the car. The diesel noised just started about a month ago. I've only had the car since June and I've heard this is a common problem.
Old Oct 25, 2007 | 12:55 PM
  #80
Rastven's Avatar
Rastven
The dieseling sound has something to do with the direct injection system if I recall correctly.
Old Oct 25, 2007 | 01:49 PM
  #81
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
While most owner's situations can get away with extended oil changing intervals, there are those who live in colder climates that make short trips of less than ten miles or so per day or idle their engines in efforts to warm them up. In these situations, the moisture from the combustion process that finds it's way into the crankcase never has a chance of being fully boiled off. This is considered extreme heavy duty usage and oil changes need to be more frequent, preferrably with the changes being made during the peak of the cold season. The moisture that collects in such engines is very acidic, and does quite a number on engine internals.
Old Oct 25, 2007 | 03:49 PM
  #82
r56mini's Avatar
r56mini
After I changed the oil, I noticed the car is about 15 whp stronger and the engine doesn't make diesel like sound anymore. Man, I can't wait to make fun postings like this all day on April fools...
Old Oct 25, 2007 | 04:09 PM
  #83
Robin Casady's Avatar
Robin Casady
When I changed mine, you could see demons in the oil that was removed.
Old Oct 26, 2007 | 09:42 AM
  #84
eeterp's Avatar
eeterp
I noticed that too on my test drive. Apparently it's normal for direct inj. It almost has a "ticking valve" sound. Definitely, something to get used to.
Old Oct 26, 2007 | 10:17 AM
  #85
jrh0558's Avatar
jrh0558
Actually, if my memory’s correct, early in the shuttle program, the space shuttle had an aborted launch because of used contaminated oil.
John
Old Oct 26, 2007 | 10:53 AM
  #86
jascooper's Avatar
jascooper
If you look at the upper right of the picture you posted, you'll notice it is not appropriate content. Cool image though...
Old Oct 26, 2007 | 01:13 PM
  #87
Robin Casady
If you click on the image itself you will find out that it is a detail from:
The Temptation of Saint Anthony painted by Grunewald between 1510-1515.
The original is in the Musee d'Unterlinden, Colmar
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
