R56 Anyone consider the BMW 135i instead of an MCS
Old Jul 22, 2007 | 06:56 PM
  #26
ED955S's Avatar
ED955S
3400 lbs is lighter than the current 335i sedan which can go 0-60 in approx. 5 sec . This car will be fast and after-market sway bars or suspension components will be there in no time to further balance the handling deficit if it's true but I am sure that handling will be great even in stock form as it is a BMW...and RWD.
Old Jul 22, 2007 | 07:08 PM
  #27
Dr Obnxs's Avatar
Dr Obnxs
Found the Top Gear...
and it's much kinder than I had realized. I think that if it hadn's suffered from BMW pricing (base is pretty stripped, and adding options can add tons of $) then they'd have been happy with it.
http://youtube.com/watch?v=wREuKF16a_U
It does look fun to drive when he's sliding around the wet track...
Matt
Old Jul 22, 2007 | 07:23 PM
  #28
msh441's Avatar
msh441
Originally Posted by aus
The reason I post here is because it seems the price will be pretty close to a loaded Cooper S (estimated $35k), and very close to a JCW MCS (guestimated price).
The 135 will have 300HP and 300 ft-lbs of torque. It'll basically fly. I've been thinking about it since it's just a little more than a loaded MCS and will be FAST. I know it doesn't have the heritage in the same way as the Mini, but it being touted as the present day 2002, which pretty much defined the sports sedans for BMW.
I have a loaded R56S (minus only the Nav and Convieniencs packages)... I came in UNDER $33K after taxes and everything. No JCW yet, though.
A BARE BONES 1-series is going to start in the mid $30K range. I believe that's without the twin turbo and I would assume that little addition will push the car into the upper 30's...
Add some minor accessories and the turbo 1-series is going to be a $40,000 car, easy. So I don't think these will be as closley priced as you might think.
That, and as it's been pointed out, the 1-series looks like it's going to be pushing the scales a bit more than many had hoped. It's no lightweight (considering the small size), by any means. But hey. It's pretty... and BMW rarly builds an poor handling car, so maybe it carries its girth better than expected.
Old Jul 22, 2007 | 07:28 PM
  #29
Dr Obnxs's Avatar
Dr Obnxs
The one on Top Gear
was over 31k british pounds! Yikes!
Matt
Old Jul 22, 2007 | 07:32 PM
  #30
PGT's Avatar
PGT
you can buy a 335is for $40k. The 1 series will be signficantly less
Old Jul 22, 2007 | 07:33 PM
  #31
SPDinNY's Avatar
SPDinNY
the 135i is twin turbo and starts at 35k, the 128i is going to start around 25k. I imagine with the suspension I am going to get and the LSD I will be close to 40k when done. I just hope the FJ continues to hold its value til spring.
check out www.bmw128i.com for more info
Old Jul 22, 2007 | 07:37 PM
  #32
Dr Obnxs's Avatar
Dr Obnxs
Here's something to ponder...
from the official press release....
"TeleService automatically notifies the BMW center when a vehicle will need service. This feature allows the Service Advisor to proactively set up a customer appointment and have the needed parts ready."
Wonder what it will say when the dealer gets the message "Car running at 240% of rated torque!" or "highest boost was 28 psi"..... I guess the modders can always pull the antenna...
Matt
Old Jul 22, 2007 | 07:41 PM
  #33
PGT's Avatar
PGT
LSD? it's not even optional on the 335i, to protect M3 sales
Old Jul 22, 2007 | 07:45 PM
  #34
SPDinNY's Avatar
SPDinNY
it will be on the 135i. The new M3 will be out before this I think. This is not in the same league as the new M3.
Old Jul 22, 2007 | 07:49 PM
  #35
PGT's Avatar
PGT
oh, I think it is. I've driven two 335i's (one Vishnu modded) and clearly, the TT motor is a force to be reckoned with.
Old Jul 22, 2007 | 07:58 PM
  #36
SPDinNY's Avatar
SPDinNY
I guess your right about the LSD.
DSC system on the 135i Coupe is designed specifically for performance-oriented driving.
For instance, the accelerator pedal has a quicker response rate and electronic rear brake
management is used to simulate a differential lock for stronger acceleration in turns.
Old Jul 22, 2007 | 07:59 PM
  #37
Mocker's Avatar
Mocker
The 135i also has fixed caliper multi-piston brakes. That's a first for any production BMW.
It's the car the e30 and e36 M3 (not to mention the 2002) guys have been asking for ever since the M3s started bloating. It is a formidable car and should be quite "tweek-able."
Old Jul 22, 2007 | 08:01 PM
  #38
r56mini's Avatar
r56mini
If Mz4 is slower than 135.....I don't know what M's reputation will suffer.
Old Jul 22, 2007 | 08:06 PM
  #39
z3bum's Avatar
z3bum
Who is considering the 1 series instead of a MINI? I figure if I really like the 130i, I'll get the cabrio! It will be bigger than the MINI, but definitely a summer, spring and fall car. The MCS is my workhorse, so the 130 would be the sporty car!
Trouble is it will be a long time before even the coupes are in the US, and from the pictures, it is hard to tell what they really look like.
Old Jul 22, 2007 | 08:09 PM
  #40
alisor56's Avatar
alisor56
Im actually considering trading my 07MCS for the coupe, or even the M1 model. But never know, might just have both the MCS and 135i
Old Jul 22, 2007 | 08:35 PM
  #41
r56mini's Avatar
r56mini
both mcs and 135 would be nice.....my MCS is the fun car and my e30 is my daily beater.
Old Jul 22, 2007 | 11:53 PM
  #42
aus's Avatar
aus
If those are BMW figures for the weight, it'll be a little better since they given weight including a tank of gas and a 70kg driver... which should be a 85kg driver in the US.
It'll be pretty cool if it has a mechanical LSD and multi-piston brakes. I just hope BMW finally gives it's cars decent looking brakes.
Old Jul 23, 2007 | 04:46 AM
  #43
Skuzzy's Avatar
Skuzzy
Doesn't do a thing for me.
Old Jul 23, 2007 | 04:50 AM
  #44
LannyMCS's Avatar
LannyMCS
I'm gonna look at it when it shows up......
Old Jul 23, 2007 | 05:05 AM
  #45
Drillslinger's Avatar
Drillslinger
I wound up test driving the MINI back in late 2005 because I thought the E90 330 and 325 were just too big for my taste. Naturally, once I got behind the wheel of the MINI I was hooked However, the 135 seems to address the issues I had with the 3er (won't know 100% until September) but if BMW prices this right (i.e. they DON'T price it as if it were a mini-//M) then I'll seriously consider it vs the Clubman (Different cars, I know, but our 2nd car will need to simply be a little larger)
Old Jul 23, 2007 | 06:41 AM
  #46
Dr Obnxs's Avatar
Dr Obnxs
One item to note....
is that the rear space is really, really limited. So when it shows up, it will be interesting to see if the back seat is for anything more than puppies and groceries! If the rear seat room is anything like the 130 that top gear ran, then for all intensive perposes it's a two seater!
Matt
Old Jul 23, 2007 | 07:12 AM
  #47
Mocker's Avatar
Mocker
"Intents and purposes?"
Old Jul 23, 2007 | 07:45 AM
  #48
cnolan
1-Series
I think the original poster is talking about the 1-series COUPE, which is slated to go on sale in the US.
HOWEVER, the 5 door has not been confirmed. BUT I SAW ONE ON THE ROAD a few weeks ago, with distributor plates
I live in SoCal. This was on PCH in Sunset Beach.
This is a 1-series 5-door hatch. Was not a diesel, but had no markings, so not sure what engine.
This was driving along one of the new M3's (to be released).
I see factory BMW cars all the time around here. Saw a new M3 with heavy body cladding almost a year ago.
Attached Thumbnails Anyone consider the BMW 135i instead of an MCS-photo_062507_003.jpg
Old Jul 23, 2007 | 07:51 AM
  #49
PGT's Avatar
PGT
the five door hatch, I would buy. It's perfect for me. If it's not coming, I might look at something else to replace my MINI...maybe the new STI hatch
Old Jul 23, 2007 | 07:55 AM
  #50
Dr Obnxs's Avatar
Dr Obnxs
I think
the 128i hatch would sell really well to the college age crowd.
And it's good to see the BMW putting some big motors in the smallest car. That's always a recipe for fun!
Matt
