R55 Recurring p115c engine code
Old Feb 27, 2023 | 09:39 AM
JKN mini's Avatar
JKN mini
I own a 2009 mini clubman base that I bought about 5 months ago. The car had issues mostly cosmetic (or so we thought). About 2 weeks after we bought it the check engine light came on. Scanned the code and it returned p115c which corresponds to a lower air intake than expected. We replaced the mass airflow sensor and I was good for 3 drives, then the code came back. We then took it back to a shop and had both vanos solenoids replaced. That lasted for another 3 drives. We then put on a k&n intake. It seemed to fix the issue for a while, but the code will still come on intermittently with more spirited driving. It drives fine while the engine light is on with no noticable dips in power. Our mechanic advised us that to truly get the issue resolved we should get the ECU flushed. What should we do you solve this issue?
Old Feb 27, 2023 | 10:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The code means the measured airflow is lower than expected when compared to the engine rpm and throttle input.
Make sure the MAF sensor is installed in the correct orientation. There should be an arrow on the side indicating air flow direction. The arrow should point towards the throttle body.
Also check the intake tubes and manifold for leaks between the MAF and throttle body, and the intake manifold.
There is also a plastic PCV tube that goes from the back of the cam cover tot he intake manifold. This tube is know for cracking as it ages. I would check it for cracks and leaks, and plan on replacing it.
Old Feb 28, 2023 | 05:37 AM
crazy4trains's Avatar
crazy4trains
Please don't flush your ECU down the toilet. Not sure how that will help???
Scooter24
Dec 17, 2022 05:51 PM
Colby Audette
Jun 9, 2019 09:30 AM
eyan212
Jun 26, 2015 06:55 PM
pappasmurf
Feb 10, 2014 07:13 PM
davidmini
Apr 15, 2011 09:34 AM
