R55 Need Help finding replacent lower bolt for Intake Manifold
Old Aug 29, 2022 | 05:50 PM
none77's Avatar
none77
I need to replace the bolt that goes through the bracket, and into lower part of intake manifold. fI know the size, I can probably purchase locally.
The crossover water pipe on the Wife's 2009 R55 was leaking where it enters the Waterpump. I watched a couple videos, and read some tutorials, but I couldn't remove the waterpipe with intake manifold in place. It was banging against the transmission linkage, and seemed very tight. I suspect the Non-turbo Intake must have a less space, because I used a lot of force and couldn't remove it. The lower bolt is really tight, and difficult to get off. I dropped it, and haven't been able to find it. I considered just leaving it off, but not sure if I can get away without it. I read on an online tutorial that its 9mm head, but I'm pretty sure I found a 10mm to be best fit.
Hoping someone here can help.
Thank in advance,
Lou
Old Aug 30, 2022 | 03:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Your car is not turbo? Looks like it’s an m8x30, bolt #6, part number 07147543380:
https://www.realoem.com/bmw/enUS/sho...diagId=11_3952
https://www.ecstuning.com/b-genuine-...t/07147543380/
Old Aug 30, 2022 | 06:35 AM
none77's Avatar
none77
Thank you! This is exactly the information I need. You are correct its "Non-Turbo" model.
Old Sep 1, 2022 | 08:03 PM
none77's Avatar
none77
Lower intake bolt m6-30
I ordered m8-30 bolt and it didn’t fit. My car is m6-30 for bolt that goes into bracket
Old Sep 2, 2022 | 06:25 AM
none77's Avatar
none77
The bolt for my wife's R55 Non-turbo is M6-20. I looked up the parts on Real OEM, and bought replacement (M8-30) but it didn't fit. I might have mis-read the exploded diagram, but it pretty clearly looks like bolt #6 goes through the top hole of the bracket. I noticed that the bracket is easy to see with Intake Manifold removed. I took a picture, and made a mental note of the approximate distance from edge of valve cover, to bracket location. I originally started using an inspection mirror, but there are several wires that make it difficult to see with mirror. https://www.realoem.com/bmw/enUS/showparts...
Old Dec 18, 2022 | 03:59 AM
keduMINI's Avatar
keduMINI
Glad you got this sorted, mate. For reference, i typically get this type of metric hardware locally rather than ordering it with shipping.
Lobotomy
Jun 6, 2022 03:00 PM
uzun
Dec 2, 2020 07:37 PM
PhoR53
May 14, 2016 12:13 PM
xizor
Oct 3, 2012 06:29 PM
