R55 Windshield cowl molding 2014 Clubman
Old 06-09-2018, 01:56 PM
Keifus's Avatar
Keifus
Keifus is offline
Having a bit of trouble with the seal (51312756196) after replacing the cowl covers. Covers are not laying flat against the windshield. Thanks in advance...
Old 07-12-2018, 08:35 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
welcome aboard...
I assume you did it while the wipers are removed. did you make sure pushed it against the windshield and put some silicon to hold it?
Keifus (07-12-2018)
Old 07-12-2018, 08:45 AM
Keifus's Avatar
Keifus
Keifus is offline
Thanks, I had everything removed (cowls, wiper-arms) when I put the seal in and with a little finessing I got everything back together.
Seems the cowls were not snapped down all the way. All good now!!!
Old 07-12-2018, 08:46 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Good work my friend...glad it's sorted out
Old 08-20-2018, 08:11 AM
bugeye1031's Avatar
bugeye1031
bugeye1031 is offline
Moderator
The difficult part for me has been the rubber seal at the bottom of the windshield glass....the cowl has to fit into that in order to fit flush against the windshield.....
I've tried installing the rubber seal on the cowl first, but that didn't work....installing it on the windshield first and then pushing the cowl so it fits into the rubber seal worked and was easy.
Keifus (08-20-2018)
Old 08-20-2018, 02:11 PM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
More info here: But like bugeye said, push the seal up on that bottom window. If the glass has been replaced by a windshield glass company make sure they did not put on too much betalink (aka windshield sealant) otherwise it will not slide all the way up and hold on.
https://www.northamericanmotoring.co...ld-cowl-3.html
Keifus (08-20-2018)
Old 08-20-2018, 02:28 PM
Keifus's Avatar
Keifus
Keifus is offline
Thanks again...
Welcome.
RandyBMC
How to
112
02-08-2020 11:13 AM
ajstefanacci
05-10-2017 06:21 PM
andy@ross-tech.com
04-08-2003 09:13 AM
VAmini
03-22-2003 07:31 AM
SilkGreenGreg
11-13-2002 06:42 PM
Quick Reply: R55 Windshield cowl molding 2014 Clubman
