R55 Hard Starting
Old May 30, 2016 | 09:33 AM
vistaracer's Avatar
vistaracer
Hard Starting
I have a 2010 Clubman S with 80,000 miles. Recently it has been hard to start only in morning the first time. It will run rough and not accelerate. I have to give it about half throttle while I crank the engine and then keep it about 2000 rpm for a few seconds. Then, it starts fine and runs fine the rest of the day. Gas mileage is great and performance doesn't seem to be suffering I have a Scan Gauge and have the following codes showing- P0300,P0001,P0302, P0203,P0103, P0403, U3F00,B2A00,B2AAA. Anyone have any ideas?
Old May 30, 2016 | 09:46 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
High pressure fuel pump is a good bet.
Old May 31, 2016 | 08:57 AM
HPFP is a good place to start.
https://www.northamericanmotoring.co...r-r56-jcw.html
Old May 31, 2016 | 02:31 PM
vistaracer's Avatar
vistaracer
Any other way to confirm? I hate too spend $1000 and then find out that is not the problem.
Old Jul 6, 2016 | 04:13 AM
MiniToBe's Avatar
MiniToBe
Buy it on ebay for much less than that. The p0300 codes are misfire codes. Check pressure amd spark, if both are good, there goes your pump.
Also check car-part.com
Update us when you can
Old Jul 13, 2016 | 06:12 AM
bugeye1031's Avatar
bugeye1031
Moderator
For what it's worth, I had the same hard starting issue at about 120,000 miles and replaced the HPFP (before the price jump) and my problems went away. I didn't have any codes, though.
thelawson
Apr 13, 2016 11:04 AM
rt808
Apr 6, 2016 08:59 AM
Drumsound
Mar 17, 2016 05:36 AM
Lewis Lee-Martin Williams
Mar 14, 2016 07:36 AM
GAT
Mar 11, 2016 11:08 AM
