R55 Wastegate Actuator replacement.
Old Feb 17, 2016 | 06:43 AM
ClubmanAssault's Avatar
ClubmanAssault
My wastegate actuator is stuck open so no boostieee!!!! Where can I find another stock actuator? Are there any aftermarket Wastegates that can be used to replace the stock one and installed easily.
Old Feb 17, 2016 | 09:24 AM
05r50's Avatar
05r50
http://www.jmturbocoopers.com
This guy carries parts.
Have you tested the actuator with a vacuum pump to make sure it is the problem? The actuator moves the waste gate in the exhaust housing of the turbo. If the WG is bad then you need to replace the exhaust side of the housing or the entire turbo. Either way this vendor has what you need.
In my case the WG itself was broken. The actuator was working.
Old Feb 18, 2016 | 07:56 AM
ClubmanAssault
Yes I had it tested by the Mini dealership. They brought me back and showed me. This mini was purchased with 127,000 miles on it and it is really showing it. I'm trying to get it fixed as cheaply as possible. Thanks for your reply.
dw3
Aug 29, 2016 10:24 PM
zipitydooda
Mar 29, 2016 12:42 PM
Fooj GP
GP Talk
Feb 22, 2016 09:59 PM
buzzsaw
12
Feb 18, 2016 11:14 AM
takrdown
Feb 17, 2016 07:33 AM
