R55 Parking lights flash
Old Jan 27, 2016 | 10:00 PM
db21637's Avatar
db21637
I tried searching for established threads on this topic but found none, I apologize if this topic has already been addressed. The parking lights on my 2011 S Clubman will flash when starting and randomly while running. The lights will flash in unison L & R then alternate L & R. It appears that the front & rear are always in sync. Time of day and ambient light seem to have no effect. I have recorded video but the flashing always seems to be out of sync (flash per second) with the recording speed (frames per second). There are no warning messages and all lights function normally. Whatever the issue, there appears to be no negative effects. I do not know when this started, I only noticed it approx 2 moths ago when I was behind a pickup with a very large chrome rear bumper and I started my car.
This is a link to a video. https://drive.google.com/file/d/0B0F...ew?usp=sharing
Any help or info will be greatly appreciated.
Old Jan 27, 2016 | 10:24 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Random stuff like that can be signs of battery going bad. Have it tested would be the first thing I'd do.
Old Jan 28, 2016 | 09:34 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Strange! Yes, if the battery is on its way out all sorts of weird electrical gremlins can happen. If that is ruled out of the equation, let us know.
888.280.7799 | 6am - 5pm PST
Old Jan 28, 2016 | 01:57 PM
Did you put leds in the turn signal bulbs ? Then that's the bulb check part of the LKM , when you put in leds ( instead of halogen ) , only at start up the they will do the flash and then the cop light flash. The LKM is looking for resistance in the system.
So its normal if you have leds or Ziza leds on the front. Only does it at start up for a fews seconds.
https://www.ecstuning.com/Search/SiteSearch/ES2684738/
Old Jan 28, 2016 | 02:06 PM
db21637's Avatar
db21637
I do have LED but I made sure they are canbus to avoid errors with the computer. Oliver has an appt with MINI service on Monday to have the hpfp replaced. I will have them run diags from the service computer and update status when I get him back.
Old Jan 28, 2016 | 02:25 PM
Yep, LED that are canbus still do the light dance, so its normal Canbus just keeps the bulb out error from popping up.
Grip Grip
Jan 16, 2016 04:47 PM
tylewis
Jan 11, 2016 09:16 AM
bpatters69
Jan 8, 2016 07:27 AM
Jan 6, 2016 02:20 PM
gabber
Dec 31, 2015 09:26 PM
