R55 Light Bulb warning light
Old Dec 17, 2015 | 12:15 PM
lyonsfin's Avatar
lyonsfin
Hi. I am getting an intermittent "light bulb" warning in my '08 Clubman S. I have checked all exterior lights when it is lit (and when it is not) and I can't find any that are out. Any ideas? Is there a way to identify which one with the "Check system"/?
Old Dec 17, 2015 | 12:22 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did you check the license plate bulbs as well? Check out this NAM thread here for viable options. Post #14 was their issue.
888.280.7799 | 6am - 5pm PST
Old Dec 22, 2015 | 08:09 AM
nkfry's Avatar
nkfry
There could be a bulb with a cracked filament that is making intermittent contact, or the bulb has become loose in the socket. Unfortunately if you don't have a dealer level tool that will tell you which bulb is faulty, you will have to visually confirm what the problem is.
You haven't replaced any of the exterior lighting with LED have you?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 22, 2015 | 08:15 AM
lyonsfin's Avatar
lyonsfin
Thanks. Turns out it IS license plate lights. If I tap on the bumper they come back on. I pulled out the bulbs and reset them in the holders, but still intermittent. I will change the bulbs and see what happens. Interestingly, the warning will come on when the switch is set to automatic, but the lights are not on. Both of my BMW 540s had a similar issue with rear parking lights!
Old Dec 22, 2015 | 08:22 AM
nkfry's Avatar
nkfry
Bend the connections in a bit to create a more positive connection on the bulbs, I've had to do that on multiple cars.
Phone:586-792-6464
Old Dec 23, 2015 | 10:47 AM
Its the post, they sometimes flare out and dont touch or corrosion get in there.
Also check that plug socket itself. Its might be corroded on the back.
https://www.ecstuning.com/Search/Sit...104/ES2675450/
If you want to upgrade to leds , see here :
I have been running the Ziza ones for years , no flicker or bulb out error.
Here they are for the Clubman :
http://www.ecstuning.com/Search/SiteSearch/ES2602932/
Flygirl
Dec 10, 2018 11:13 AM
laneess
Mar 15, 2016 12:35 PM
racemini
Feb 26, 2016 01:53 AM
Mini_Touge
Dec 23, 2015 11:26 PM
Toolz
Dec 17, 2015 11:01 AM
