R55 Newbe, 2011 Clubbie S
Done a lot of reading! I have a little concern about the engine heat issue. One post stated that by removing the grill in the scoop that it would drop the temp by 10 degrees? Any other thought or experience in this area? Pros/cons...thanks
I took out the factory grille in the scoop and replaced it with a mesh screen for appearance only. I couldn't be able to give you any info on it reducing temps but I will tell you plenty of heat vectors out that hole after spirited driving.
These MINIs run hot so it's pretty normal. Some of the cars came with the entire scoop plugged off.
We replace the stock plastic scoop insert with the open metal grill one to help.
http://www.waymotorworks.com/mini-fi...oop-grill.html
Then I also put in the hood heat shield, has to be notched to put on the newer hood that has the brace go through, but it works well.
http://www.waymotorworks.com/mini-co...5-r56-r57.html
Otherwise I wouldn't put too much worry on it. But this is why open intakes don't make power on the Turbo MINIs.
Congrats on the Clubman
For the scoop , get the heat shield.
https://www.northamericanmotoring.co...ut-this-2.html
If you want the factory scoop grille , newest version its here.
has some vents for the heat.
http://www.ecstuning.com/Search/SiteSearch/51232752275
Welcome to NAM! Would love to see some pictures of your Mini.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
