R55 Will these Wheels fit?
Old Nov 25, 2014 | 08:06 AM
lowsinthe20s's Avatar
lowsinthe20s
Looking at a few sets of wheels. Will these fit with out issue?
18x8.5 32 offset
18x8 35 offset
Thanks in advance.
Old Nov 26, 2014 | 05:29 AM
v10climber's Avatar
v10climber
Are you lowered at all? They're unlikely to be just a straight bolt-on affair. The 18x8 et35 is obviously the easier of the two to fit. The 8.5 I think would require a lot of work to fit under the front fender without rubbing.
Old Nov 26, 2014 | 07:34 AM
lowsinthe20s
Not lower yet. I guess the question that I should be asking is. What is the biggest wheel and tire combo I can do and still be a little lowered.
Old Nov 26, 2014 | 07:40 AM
percymon's Avatar
percymon
the offset should be a bigger concern than the rim width - lower the ET number the further out the wheel and tyre. Not only will the wider track width from low ET wheels risk issues with fender clearance it will increase tramlining.
Most Mini factory wheels are around 45-48mm which is great for clearing the arches (moves wheel inboard towards suspension components) with factrory width tyres. As you increase tyre width you will need slightly lower value offsets to clear the suspension, but even increasing tyre width by 10mm should only need a ET43 wheel, increasing 20mm would need a minimum ET38 at which point you get close to the arch !
Old Dec 2, 2014 | 11:23 AM
bruno73's Avatar
bruno73
I drive 8x18 et 35 with 215/35 tires, lowered on a KW var 1 coil over. sit's just right. Wouldn't go wider. Just my thought
Old Dec 16, 2014 | 07:34 AM
lowsinthe20s
I think these wheels will work based on your comments, but not sure on the tires. Please let me know I need to act quick to pick up a deal.
Wheels are 18x8 ET 40. Tires 225/40
I'm not lowered, but I do have NM Springs waiting in the garage. 1.2 drop.
Old Dec 16, 2014 | 11:00 AM
bruno73's Avatar
bruno73
Wheels: Wheel 1 Wheel 2
Wheel size 18x8 ET 40 18x8 ET 35
BackSpace 154 mm (6'') 149 mm (5.8'')
5 mm (0.2'') shorter.
Rim Lip 5 mm (0.2'') wider
Typical Weight ~ 26 lbs / 12 kg ~ 26 lbs / 12 kg
Tires: Tire 1 Tire 2
Tire size 225/40-18 215/35-18
Section width 225 mm (8.9'') 215 mm (8.5'')
Sidewall 90 mm (3.5'') 75 mm (3'')
Tire diameter 637 mm (25.1'') 607 mm (23.9'')
30 mm (4.7%) shorter.
Rim sizes 18x6.5 to 18x8.5 18x6 to 18x8
Circumference 2000 mm (78.7'') 1906 mm (75'')
I think it will fit, since you don't have coilovers but I don't like to much tire, looks odd.
Old Dec 16, 2014 | 01:02 PM
lowsinthe20s
Thanks. I think I'm going to go with these.
Ninja 08 Wheel. All Dark gray. 18x7.5 et 45. With 225/35.
kazyn
Oct 25, 2019 02:34 PM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 7, 2015 05:56 AM
