R55 Sprintbooster install PROBLEM!!!
Old Aug 2, 2014 | 10:54 AM
Morrissey25's Avatar
Morrissey25
I just purchased a Sprinbooster from a fellow member and promptly went to install the product. Everything was as smooth as you would expect a simple plug and play to be.
However, after everything was connected, I went to start the car and then the engine light came on and there was no throttle response. I disconnected everything, checked to make sure that there was no damage to the pins, reinstalled, and nothing.
I then reconnected the wiring back to stock and the problems persist. Does anybody have any suggestions/feedback for me as my Clubman is now an expensive paper weight stuck in my driveway
Old Aug 2, 2014 | 11:09 AM
Morrissey25
I disconnected the battery and now I have throttle response. Engine light is still on and the Sprintbooster is not connected.
As I continue to do research on the product, I found that the vehicle that it was previously used on was a 2012 Countryman S (MT). I was under the impression that it would fit my 2014 Clubman (non S).
Did I just buy a product that will not work with my car? Does anybody with a 2014 Clubman have this product and if so, Part number???
I thank you all in advance for your time.
Old Aug 2, 2014 | 11:48 AM
Morrissey25
It has been a super busy couple of hours. I decided to reinstall the sprintbooster with the battery disconnected and I did have throttle response
However, when I took the car on a test drive, my Clubman was in "limp mode." The check engine light is still on and my car was completely unresponsive while driving it. I went through each of the modes on the booster (Green, Red, not illuminated) and there was no difference in performance between the three. Everything was "limp". The car was completely struggling and even though I am not a "S" model, I had no power while driving... I am still open for any help that the community can provide.
As far as warning lights, the check engine light is lit up as yellow and I am also seeing the symbol that states that the cruise control system has failed. Can I reset the indicators?
Because it is a Saturday, no service representatives are around to assist me with my car.
I am dumbfounded
Last edited by Morrissey25; Aug 2, 2014 at 12:05 PM. Reason: Added information on the indicator lights.
Old Aug 5, 2014 | 02:13 PM
CA94960's Avatar
CA94960
I wish I could help you - but I have no experience with them. Reading stories like this is why I am happy to just leave my Clubman stock.
squawSkiBum
Oct 2, 2015 09:21 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
