R55 Rubber boot panel cover?
Old May 20, 2014 | 05:07 AM
enatal's Avatar
enatal
hello.
I already have the rubber boot cargo tray in my Clubman. I am looking for a rubber mat to protect the folding top cover.
Does someone knows where can I get one?
Thanks!
Old May 20, 2014 | 06:14 AM
Hello,
You are talking about a cover to go over the hide away factory cargo cover that sides back and forth? Is so there is no factory MINI accessory for that. Also , its pretty thin cover in the first place, what ever you find would have to be light and stay in place. Good luck.
#1.
Thanks and hope that helps.
Old May 20, 2014 | 08:13 AM
jerseyclubman's Avatar
jerseyclubman
I think he meant a protective liner to go over the folding cover of the false floor. I've been looking for one also.
Old May 21, 2014 | 10:54 AM
enatal's Avatar
enatal
Clarification
What I am looking for is a rubber cover for the folding false floor inside the Clubman boot. I have not seen any merchant selling an item like that, or at least sell the rubber roll to custom cut to fit over this false floor.
If anyone knows, please let me know.
Thanks!
Old May 21, 2014 | 11:22 AM
Thanks , did not know what you were talking about.
You need a cover for the very top floor. Fits over #3 , not #1.
Here is the top carpet liner that states Clubman stitched. Part # 82110440081 This might be the best fit for protection of the top floor.
http://www.ecstuning.com/Search/SiteSearch/82110440081/
MINI Clubman Checkered Trunk / Boot Protection Space Cover Kit Part # 51470432367 If you are looking for something with more coverage for hauling and such.
http://www.ecstuning.com/Search/SiteSearch/51470432367/
There used to be this anti skid material that MINI / BMW used in the trunk but the MINI part is NLA , Mfg Part# 82129413180
This is the cover for #1 :
http://www.ecstuning.com/Search/SiteSearch/51470416184/ES120753/
http://www.ecstuning.com/Search/SiteSearch/51470416185/
Old May 22, 2014 | 04:37 PM
Jephen19's Avatar
Jephen19
MINI doesn't offer one to my knowledge. The rubber one fits BELOW the false floor. The carpet one fits ABOVE the false floor (no rubber option from MINI).
Best bet is to get this one from WeatherTech:
http://www.weathertech.com/mini/2012...n/cargo-liner/
From the looks of the picture, the sides appear to be molded specifically for the shape of the trunk above the false floor, not below it. I've heard on NAM that the MINI "all-weather floor liners" are made by WeatherTech. If that's true then the quality should be equal.
Old Mar 13, 2019 | 06:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Is there an instruction sheet available for the checkered cargo liner? I'm looking at picking one up, but I would like to check whats involved with getting it into the car.
Old Mar 13, 2019 | 07:08 AM
Hello, As you can see in the pics it has a rod that inserts on the main section right behind the seats and is like a hanger rod for a shower, then hooks and suction cups hold the side in place. I will see if MINI has an install PDF.
Old Mar 13, 2019 | 07:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks for checking. I'm sure it might be self explanatory, but sometimes it isn't. If I picked one up, I wouldn't keep it installed all the time, but would put it in and out as needed.
Old Mar 13, 2019 | 07:36 AM
Attached
File Type: pdf
Old Mar 13, 2019 | 07:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Attached
Thanks so much!!
Old Mar 13, 2019 | 07:56 AM
Welcome
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Knuckle14
Aug 26, 2015 08:10 PM
jziran
Aug 24, 2015 04:50 PM
Chasp
Aug 22, 2015 01:27 PM
