R55 Auto door lock
Auto door lock
I have a 2009 R55 Clubman S, I recently took my MINI in for service and they flashed my ECU, now my doors don't auto lock like they did before. I have tried to reprogram this feature so when I drive off the doors will lock themselves again. I can't seem to get it programed again.
Does anyone know how to set them and what icon is displayed on the tach , and how to make it stick when I exit?
Any help would be greatly appreciated.
Consult pp. 22-23 in your Owner's Manual. Remember:
Good luck!
- Some of these settings require the vehicle to be started (i.e., ignition on/engine running) or you can't access the menu option.
- Some of the settings are linked to the fob. So if you want both fobs to have a particular setting, it's a good idea to double-check that it's set to your preference when you use either fob.
Good luck!
One thing to remember when quoting manual page numbers to people. The PDF is not formatted the same so the page numbers are different between the PDF and printed versions. They both do have exactly the same information though.
And also of note is that from year to year they change. I know I have all of them down loaded and they are different
Yes, that is true; a good reminder to all. I do try to use the page number(s) printed in the manual rather than the .pdf page number(s).
techgearpro
Jul 23, 2019 07:09 PM
spackletooms
Sep 1, 2015 10:12 PM
