R55 DIY Engine Oil Pan Heater
Old Jan 15, 2009 | 05:33 PM
miniclubman's Avatar
miniclubman
I rigged up an oil pan heater using a worklight, an old loaf-sized metal baking pan, and a 150 watt light bulb. I cut a notch in the end of the loaf pan, which is about 6" wide, 9" long, and 4" high. Then I lined it with aluminum foil, to increase reflectivity, and laid the work light inside. One or two small scrap 1 x 4 boards bring the contraption just under the height of the oil pan, which is about 6" off the ground. I plugged it into a timer, and set it to go on about 2 hours before my morning commute. This morning when I checked the oil via the dipstick it was warm, not hot, and the outside temperatuure was about 17 degrees. Cost, one light bulb, about $2.
Tomorrow it's supposed to be around 5 degrees, and 2 degrees on Saturday. While this may be laughable as an engine heater setup in Minnesota or North Dakota, it's good enough for a Long Island cold snap.
Old Jan 15, 2009 | 06:06 PM
minimarine's Avatar
minimarine
That's quite ingenious. Care to share any pictures?
For a few bucks, this might be worth a try. I'm always paranoid about the cold start thing rearing it's ugly head. Maybe this simple fix will stave off the beast.
Old Jan 15, 2009 | 06:48 PM
miniclubman
Well, right now it's under my MINI. I'm just using a standard work light, the kind with a hinged metal cage around a regular light bulb. The loaf pan can be found in any grocery store. You really don't need to even alter the pan, it just makes the light lay into the pan more easily if you cut a wide notch at one of the ends, so the neck of the work light can lay flat. If you get a non-coated pan you won't need the foil lining, and they also sell disposable foil pans in a loaf shape for a dollar or two.
Old Jan 15, 2009 | 06:57 PM
Mini Mania's Avatar
How is this for an alternative?
Old Jan 15, 2009 | 07:25 PM
miniclubman
Originally Posted by Don Racine
Well, it's $99, and it won't fit the Clubman.
It also looks like a pretty complicated install, not an easy DIY.
Etrain
16
Aug 5, 2024 04:37 AM
bobbiemartin
Jan 20, 2016 05:28 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
minipopkart
Aug 13, 2015 05:22 AM
