R55 Coolant recommendation
Old Dec 29, 2008 | 02:59 PM
lurch70's Avatar
lurch70
So I am noticing that my coolant level is a bit low since I run my heater quite a lot lately.
Anybody can reccomend anything in particular to buy? Not partial to the OEM one from MINI so any good auto store types would be fine.
Old Jan 16, 2009 | 08:10 AM
gohwkis's Avatar
gohwkis
Did you find something that will work or did you end up using mini's?
Old Jan 16, 2009 | 09:09 AM
IzzyG's Avatar
IzzyG
My MA told me not use anything but blue coolant/anti-freeze. I'm thinking er, why? I believe Peak has some stuff that works with any color, although I'm wondering if it'll void warranty if anything fails. Either way I have an appointment on Monday so I'll get them to fill him up when I go in.
Old Jan 16, 2009 | 02:12 PM
miniclubman's Avatar
miniclubman
Anybody can recomend anything in particular to buy? Not partial to the OEM one from MINI so any good auto store types would be fine.
Runing your heater should not affect your coolant level. It is normal to lose small amounts to evaporation over time. If it's just a little low simply add distilled water, about 75 cents a gallon at Walmart. The difference between the "lower" and "upper" level indicators in the coolant reservoir is about 8 ounces.
If your coolant level is very low, you have a mechanical problem that needs to be looked at by your dealer.
Old Jan 16, 2009 | 07:35 PM
lurch70's Avatar
lurch70
bought some OEM Mini coolant from the dealer ... figured if the Zerex is 14 bucks at Autozone the original at 20 bucks is not a bad deal ... topped it off and added some distilled water and good to go.
that OEM Mini cooland is some really thick stuff, almost gel like.
Old Jan 17, 2009 | 08:19 PM
miniclubman
Why didn't you just let the dealer top it off for you? Isn't a low coolant issue covered under warranty? Also, how much did you add?
Old Jan 18, 2009 | 01:42 PM
lurch70's Avatar
lurch70
i guess they would have topped it off if I asked, but I was in a hurry at not at my usual dealer, and like to have a bottle of coolant around if I need it in an emergency anyway.
wasn't that much that I needed to fill ... seems to hold even now for the last few days.
Rohdeandschwarz
Nov 5, 2015 07:58 AM
sempaipaul
Oct 26, 2015 05:56 PM
Jerome R Jr W
Sep 29, 2015 11:42 AM
rikaro
Sep 21, 2015 06:57 AM
jef1f
Sep 18, 2015 02:49 PM
