R52 Did all Cabrio's come with park distance controls?
Originally Posted by GBMINI
The beeping only happens when in reverse ... put the car in reverse, get someone to stand close behind the car to confirm the reverse lights are on and to see if they trigger the beeping. It's quite short range, but within about 6" you should definitely hear it!
I find the range to work well (I think more then 6"), it starts sounding off about the garage door frame (I back into the garage) with good notice, and its to the sides to boot.
Aside from it being broken if you can't hear it, maybe the volume was just set really low - that is something the dealer programs along with other key options.
My PDC works pretty much as described in the Owner's Manual: slower beeping starting at about 3 to 4 feet, then beeping quicker until it sounds a continuous tone under 1 foot. After engaging in reverse, it takes a couple of seconds for the PDC to become active.
For rear visibility, I found that using a wide angle mirror on the passenger side helps enormously with the cabrio's blind spots. I have a Multivex mirror and it is very good. See these threads on the topic:
http://www.mini2.com/forum/showthread.php?t=96606
https://www.northamericanmotoring.co...ad.php?t=49390
If you have Navigation, the rear view camera is also a very valuable (but expensive) addition: https://www.northamericanmotoring.co...ad.php?t=53297
I've had Free Spirit for 2 1/2 weeks now. I've noticed when I'm backing into a parking spot the PDC starts beeping several feet out, the beeps are slow, but the closer I get the faster the beeps. But once I hit my brakes they stop; even if I start backing up again they don't come back on (once I brake and start again I don't back up very much more so maybe I don't move far enough to activate the PDC signal again.)
Originally Posted by rkw
Free Spirit, mine does not behave like that. As long as I'm in reverse gear, the PDC will signal if I'm close to something, whether I'm moving or not. It definitely does not stop if I hit the brakes. You should have your dealer check it.
AAUUGGHHH!!! NASCAR's on rain delay at Talladega:impatient
Sorry, back to this. I have to drive to Memphis (I'm near Little Rock, AR) so when I go up for my service I'll mention it.
Multivex...
Ditto on the Multivex mirror, I've got one on the passenger side, it's great when backing out of angled parking spaces and you're trying to get a look at what the cabrio's C pillar is blocking. Takes some getting used to as it's hard to judge distance with it but it's worth it for the extra view.
If it worked and now it doesn't, check the fuse. I had this problem and come to find out the Power Steering Fan is hooked into the same fuse now as the PDC. If the fuse is blown, check the fan to see if the bearing is going out. Try the fuse and if it blows again, take it in. They had my car for a week since MINI didn't bother to tell anyone about this mid-model "feature".
Originally Posted by Free Spirit
... once I hit my brakes they stop; even if I start backing up again they don't come back on (once I brake and start again I don't back up very much more so maybe I don't move far enough to activate the PDC signal again.)
Originally Posted by Your Owners' Manual
The warning signal is canceled after
approx. three seconds if the distance to the
object remains constant during this time,
for instance if you are moving parallel to a
wall.
wall.
molala
10-02-2015 01:53 PM
dandw2
09-06-2015 03:14 PM
Tinklespout
16
09-06-2015 11:39 AM
