R52 Whistling noise from top at 40mph
Old Aug 7, 2025 | 03:10 PM
Jordan Smythe's Avatar
Jordan Smythe
My mini top has a whistling noise when I get to around 35-40 mph (and above). This is coming from where the top meets the windshield. The rubber weatherstripping looks fine, and the top appears to be fitting snug. I tried cleaning everything up super well, and also using a "rubber seal conditioner" I picked up on Amazon for supposed sealing issues. If anything, it appears to have made the sound worse.
Any insight or next steps would be appreciated. I'm hoping to avoid completely replacing the weather seal, which seems to run about $450 everywhere. :(
Old Aug 8, 2025 | 07:10 AM
DHTaylor's Avatar
DHTaylor
Are you certain it is the window strip and not the convertible roof itself? I get the same whistle, but it is my roof. If I crack it open just a touch, it goes away. There are threads on here explaining that the motor is off just a little and all you have to do is take the cover off, and realign the guides for the roof. Check the other threads as they are more explanatory.
If it actually is the weatherstripping on your window, you might want to check a junkyard. In fact, two new vehicles just hit my local yard this week. You may be able to salvage something there.
Old Aug 8, 2025 | 09:07 AM
The convertible top needs to seal the same all the way across or it will whistle. Some people have the sunroof portion not adjusted or a cable is broken.
https://www.northamericanmotoring.co...oof-opens.html
https://www.northamericanmotoring.co...nt-of-top.html
https://www.northamericanmotoring.co...placement.html
https://www.northamericanmotoring.co...eaking-in.html
Gummi fledge if the seal is uniform and gap is the same across, and the sunroof portion is fully closed.
https://www.ecstuning.com/Search/SiteSearch/gummi/
Old Sep 6, 2025 | 04:24 PM
Jordan Smythe
Well, I end up solving this the old-fashioned way. A 1/2 inch wide (and 1/8 thick) strip of black weather seal on the top edge where the convertible top presses against the plastic. You can push it down mostly inside, and you can't even see it. Solved for $6.
VictoryDaveAZ
Sep 29, 2009 01:59 PM
CR&PW&JB
Detailing 101
Dec 10, 2007 08:31 PM
OmToast
May 22, 2005 11:05 AM
