R52 Soften hard clutch
Old Dec 27, 2019 | 01:02 AM
Aquaboy75's Avatar
Aquaboy75
Soften hard clutch
Hi everyone.
After many years with the idea of one day being the owner of one MINI I just bought one R52 116CV with manual transmission and 50000 miles. It looks like new.
Everything is perfect for me except the hardness of the clutch that I think can be a serious problem for me.
if I am not wrong my car mounts a single mass flywheel so the option of use the Valeo kit conversión to single mass recomended for the Cooper S is not an option for me.
Please, I would like to know your opinions about the possibilities ot smoothing the clutch in some way (the cost would not be a problem)
Thank you.
Old Dec 27, 2019 | 05:47 AM
cooper48's Avatar
cooper48
I switched my R53 to a Valeo single-mass unit and thought I had done something wrong during the installation because the clutch feel was so light. Not so and it performs beautifully.
Old Dec 28, 2019 | 07:58 AM
BruceJ's Avatar
BruceJ
I cat tell from your description if you have a Cooper or a Cooper S cabrio. Use the link, plug in the last 7 of your VIN. Drill down to the flywheel to see if you have a dual mass flywheel or not.
The Valeo single mass conversion kit provides a surprisingly soft clutch pedal feel.
https://www.realoem.com/bmw/enUS/select
Best Regards
Bruce
Old Dec 29, 2019 | 04:02 AM
Aquaboy75's Avatar
Aquaboy75
Thank you for the information!
Bruce, very interesting your link.
According to the information provided I am not sure what type of clutch my car owns:
01Set clutch partsD=200MM121207561754$271.80
02AT-clutch diskD=200MM1
21207560121$103.18
03Clutch release bearing1
21517536725$63.28
04Torx boltM7X146
21211043920$1.08
05Clutch rel.fork lever1
23117545083$38.70
06Pressure pin1
23117545084$2.18
https://www.realoem.com/bmw/enUS/par...52-Mini-Cooper
I think (I read it in a site I don't remember) that the clutch that non-s mount is single mass but I'm not 100% sure.
Old Jan 1, 2020 | 10:07 AM
Black Forest's Avatar
Black Forest
Non S has a spring centred clutch disk utilizing a solid (single mass) flywheel. Replace the clutch and enjoy a good pedal. I also replace the clutch slave for good measure.
Old Jan 3, 2020 | 07:38 AM
You have a Cooper "NON S" based off that vin link on realoem;
Its a single mass set up on a 5 speed getrag manual transmission with no factory pilot bearing.
Options: https://www.ecstuning.com/Mini-2006-...etrain/Clutch/
The Genuine MINI one is listed, as well as Valeo and Luk version of the OEM.
Old Jan 4, 2020 | 02:56 PM
Aquaboy75's Avatar
Aquaboy75
Thank you very much guys for the answers and for your help.
Forgive me if I don't understand it well. My English is not very good at all and I have very little knowledge of mechanics.
I understand that with the Valeo and Luk version of the OEM my pedal clutch will be lighter, is that correct or am I wrong?
I would greatly appreciate your opinion about how the Valeo version clutch for the Cooper non S compares the with the Valeo single mass clutch conversion kit for the R52/R53 S version? (in terms of pedal lightness).
Thank you!!
Old Jan 4, 2020 | 08:04 PM
Black Forest
Either one will work just fine.
Old Jan 6, 2020 | 06:55 AM
Hello,
The Cooper Valeo or Luk clutch (my link above) is the replacement i have replaced mine and the pedal feel was better then the old one but that is because it was older and used/high mileage
I have not seen a person put the 6 speed conversion kit from Valeo in a 5 speed.
Old Jan 7, 2020 | 08:00 AM
Aquaboy75's Avatar
Aquaboy75
Thank you again for your help. I think I'm not going to change the clutch to my non-s Cooper R52. I will look for a good Cooper S slowly and I will install the valeo kit Conversion.
gbfan10
Sep 5, 2019 12:34 PM
Mister
Feb 24, 2016 03:42 PM
Chase Robison
Dec 29, 2014 03:57 PM
NavyCooper
Sep 10, 2012 02:54 AM
MiniMoMir
Jan 14, 2008 02:12 PM
