R52 2005 Base convertible getting P0705 need location of sensor
Hi this is my first post. Trying to fix my daughters base 2005 convertible and have searched to find the location of the position sensor to replace it. I have found a diagram of the transmission for the S that shows it on top of the transmission. I believe the correct part number is 24157551089 I am attaching a photo of the part. Is this the correct sensor? It is an automatic, is this located under the shifting mechanism in the cab or located elsewhere. Again I did search the forum and read through the post and apologize if I somehow missed this info. Below is the info on the code as well. Code will come and go on it's own so I am trying to get this replaced before I have a major issue. Car does not seem to have much pickup in automatic mode but when I switch to manual mode it seems to be fine. Appreciate any info.
It looks like part 24157551089 is for an S model and not applicable for the base model. I am wondering if the transmission control module is the issue, probably need to have it looked at by someone to diagnose the cause of the issues we are having.
numbersix
35
03-25-2023 07:49 AM
Navigation & Audio (Speaker) location, location, location ...
Bianca
05-20-2003 03:39 PM
