R52 Odd knobs on my R52
Old Sep 16, 2016 | 08:44 AM
barry304's Avatar
barry304
Odd ***** on my R52
We recently purchased a 2005 Cooper S Convertible and couldn't be happier. I'm predicting some issues but it is the 6spd and the power steering issue was fixed under recall.
However, I've seen pictures of many MINIs and can't explain the fours *****/posts that are at the base of the A pillar and rear of the car. It looks like a mount for some kind of rack attachment? Any ideas?
Also, the seller was the second owner and didn't use the accessory bluetooth control (outboard). Can someone explain how to set up a bluetooth connection? I hold the voice button and SETUP displays and then after trying several voice commands, you hear "sorry" through the stereo.
thanks,
Barry
Old Sep 16, 2016 | 11:24 AM
Hello Barry,
Post up a pic so I can see what it is.
Factory MINI Cooper BMW ULF Bluetooth kit : I have that kit also. Very rare.
https://www.northamericanmotoring.co...-retrofit.html
Old Oct 8, 2016 | 06:51 AM
barry304's Avatar
barry304
front warts at base of A pillar
rear warts to either side of the boot.
Sorry for the delay. Here are a couple pix of the "warts".
Old Oct 8, 2016 | 06:53 AM
barry304's Avatar
barry304
the circled device on the right.
Here is a picture of the add on Bluetooth rig. Thanks for taking a look.
Old Oct 8, 2016 | 08:11 AM
Fly'n Brick's Avatar
Fly'n Brick
Only thing I can think of for those *****.
Attached Thumbnails Odd knobs on my R52-boris-karloff_frankenstein_hd_768x432-16x9.jpg
Old Oct 8, 2016 | 08:45 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Car cover attachment point?
Old Oct 8, 2016 | 09:43 AM
ZippyNH's Avatar
ZippyNH
The Bluetooth is aftermarket...pretty sure... factory buttons were usually on the steering wheel...might be a GOOD thing...the factory gen1 version was late to the market (about 2006 even though buttons started appearing on the steering wheel in 2005)....
So if you poke around, you might find the module and a model #.
The studs....guessing that maybe it was a cover...but never seen them before.
Old Oct 8, 2016 | 03:49 PM
rkw's Avatar
rkw
It's the OEM "Hands Free" Bluetooth dealer add-on accessory.
http://motoringfile.com/howto/offici..._bluetooth.pdf
BTW, this document has Bluetooth pairing instructions, which you asked about in another thread.
Old Mar 20, 2017 | 10:37 AM
barry304's Avatar
barry304
Thanks. I agree and believe it's the full kit. I've seen the posts that included the install and pairing guide for the hands free system kit
but my kit has the voice button on the control module.
I'm still confused how to pair my phone because when I watch the video in the thread, I should be able to turn the ignition to position 1 while holding the button in the armrest area down for 2 seconds to establish pairing mode but nothing happens. If I release and press the button, It prompts for a voice command and PHONE displays on the radio.
Old May 15, 2017 | 11:15 AM
Did you ever get it to pair?
Old May 15, 2017 | 11:19 AM
barry304's Avatar
barry304
Thank you, I did. I was lucky enough to find the pairing code written in some of the vehicle documentation files. However, the connection drops and is buggy. I have a Samsung Note 3. Maybe the module doesn't like Android.
Old May 15, 2017 | 11:27 AM
Great! Its also on the module itself and its 4 digit number sticker on the module (located behind the speedo itself, you have to pop the speedo out to see it) which if not in the owner's booklets.
Old May 15, 2017 | 02:12 PM
Capt_bj's Avatar
Capt_bj
ever figure out the "warts" ?
some sort of cover for the 'vert top makes sense but curious .....
TJANK
Jul 31, 2019 06:23 AM
TJANK
Aug 15, 2016 11:28 AM
madminii
16
Aug 13, 2016 01:32 PM
snowmanmini
Aug 9, 2016 06:29 PM
1ZippyR53
Aug 6, 2016 08:10 PM
