R52 Help! Just added freon now mini struggles and warm air
My 2005 Mini Cooper S a/c was blowing cool, but not cold enough, so I went to Autozone and bought a can of r134a. Turned the a/c on full with full a/c set, let it ran for a few minutes and started to add freon. The temp outside was about 85, set the dial for 85 and the a/c pressure was at about 30. I emptied the can into the a/c and while it was still running I checked the car inside, nice and cold.
So I shut it down and went inside to get receipt to return core. Now my a/c struggles to run, the engine will struggle to run when a/c try to blow cold, and no cold air at all. The engine will struggle so much that it's noticeable, happens about every minute and last 1-2secs.
Did I add to much? If so, can I take some out? Do I need to go to the auto shop and have it flushed and re-added? If so, how much is that?
Thanks,
Mike
Thanks,
Mike
Ok, talked to my mechanic buddy and he said to release some a/c pressure by pushing in the release valve on the lower intake. I did that a few times and now the a/c blows cold and the engine is behaving.
Quick question though, what should the pressure be with the engine off, engine on, and engine on with a/c at full. A/c at full my gauge read 38-50.
Change the filter and you’ll see the A/C come back to life.
Rich
lucky you did not blow the seals out of the AC compressor. If you dont have proper gauges let an AC shop look at it. I had to replace the AC compressor on my 03 was over $700 at a local shop he was half the price of some of the others.
lalroma
20
Apr 2, 2022 06:19 PM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
Apr 20, 2018 09:31 AM
