R52 To mod or not to mod.....?
Old Jun 6, 2010 | 11:17 AM
  #26
jonasandezekiel's Avatar
jonasandezekiel
Originally Posted by HeavyMetal
For suspension/wheels, I have : 18x8 polished wheel with 215/35R18 with a 22mm rear sway at the maximum setting. But, with those wheels and the bad roads we got in Quebec, I think 16x7 with 205/45R16 will be a better choice.
I think after my re-tune, my MINI will be around 250hp at the bloc (or even more).
I agree with the 16" wheel choice..MUCH better. Even here in CT, I'm thinking about eventually swapping out my 17" wheels for the 16s.
I would also think you might want to add some underbody bracing, to help counteract all that POWER...it will make the wheels stick to the road much nicer!
Old Jun 6, 2010 | 02:07 PM
  #27
inimini2007's Avatar
inimini2007
Just look at the IE lower strut brace because it's the same as the MINI-Madness brace and it's $34.00 cheaper...
Old Jun 6, 2010 | 02:08 PM
  #28
inimini2007
If you do 16's...205-55-16 will work also.
Old Jun 6, 2010 | 06:35 PM
  #29
jonasandezekiel
Will do! 34 bucks is 34 bucks.
Old Jun 6, 2010 | 06:46 PM
  #30
jonasandezekiel
IE and Mini Madness have a steel version, but check out MiniMania, they give you choice between the steel version and an aluminum one, for about (30?) bucks more. Not sure if you've seen that one. Might be worth it for the fanatics like me--a little lighter, and rust resistant on top of it.
Old Jun 7, 2010 | 05:38 PM
  #31
inimini2007
I would get the steel...aluminum is like trying to catch the Great White Shark on a 10LB Test Line.
Old Jun 7, 2010 | 05:40 PM
  #32
inimini2007
The IE is powder coated...
Old Jun 7, 2010 | 07:05 PM
  #33
jonasandezekiel
Aluminum has great strength to weight properties from what I remember. I'm no expert in metallurgy, but it seems to me that it could be at least a little lighter, and corrosion resistant too....all good things, no?
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
