R50/53 Antennae Comparison
Antennae Comparison
Just saw a brand new R56 from my 3rd floor office. The antenna appeared to have a fatter base, wider whip, and to be taller than the R53. Can anyone confirm this? If there is a change, are the antennae interchangeable?
I haven't compared them side-by-side, so I can't say if they're taller. The base on the body is larger, with a rear fin.
But I can confirm the antennae are not interchangeable. I believe it's 6mm thread rather than 5mm. I found a stubby replacement (though I'll probably end up replacing that for aesthetic reasons) from a company that sells them somewhat generically and it came with three screws to use with it to adapt to three different mounts, and the larger one worked just fine.
