R50/53 Correct headlight aiming?
Old Apr 19, 2008 | 01:16 PM
  #51
Goodwood's Avatar
Goodwood
Mystery Solved! THIS COULD HELP YOU TOO!
I bought my daughter an '03 CVT for her 16th birthday ('03 MC VR/W CVT "Nigel") and was going through it fixing, cleaning, polishing, waxing, etc.
I couldn't get the passenger side headlight aimed... always too low, no matter how much I turned the adjusting screw... I asked lots of questions on this thread and others, all of you gave the same advice: it's easy, it's those two black screws with the slotted hex head, just a little turn goes a long way, etc.etc.etc.
I knew I wasn't that stupid, although I can imagine all of you thought I was, and I began to wonder myself, when I just couldn't get this headlight aimed, if I really was that stupid. How hard could this be?
Today I decided I was going to get to the bottom of this if it killed me. Here's what I found, maybe it will come in handy for others sometime in the future:
I was turning the correct aiming screw. On the end of the aiming screw there's a ball... it's molded into the end of the screw just as the whole screw is molded plastic... the ball end of the screw (which you can't see unless you start taking stuff apart) fits into a white plastic socket (the old ball & socket assembly!!!). The socket is part of the headlight assembly that moves. Moving the screw in and out, WHEN THE BALL END IS CORRECTLY SEATED IN THE SOCKET, causes the headlight to move up and down (or right & left if you're adjusting the other screw). My problem was that the ball end of my adjusting screw had come out of the socket! Screw the screw in far enough to pop the ball-end back in the socket, and VOILA! everything works like it should. Turn the screw now and the headlight aim goes up and down!
I don't know what idiot before me messed with this headlight, but I'm guessing they unscrewed the screw far enough to pull the ball-end out of the socket unknowingly... probably when they changed the light bulb, which I discovered they installed upside down (it wasn't seated properly in it's correct spot).
I feel much better now.
P.S. I liked my daughter's MC so much I bought myself one from someone I found on this website. Very cool all the way around.
Old Mar 17, 2009 | 08:02 AM
  #52
jbewley's Avatar
jbewley
Originally Posted by Rawhyde
Unfortunately I don't have a pic, but I'll try to describe it to you.
Each headlight has two adjustment screws. They look like a hexagon that extends about 3/4 inch from the back of the headlight housing. There is a slot cut across the hexagon so you can use a straight blade screwdriver to turn them. Loosen to raise the light. The INBOARD screw is for up/down and the OUTBOARD screw is for left/right.
Take it out on a dark country road and make some adjustments! These adjustments are very sensitive. Most likely much less than a full revolution will do the trick.
Every MINI owner I've helped with this has said, "Wow! Now I see what the big deal is about xenon headlights!!" (or words to that effect)
I've heard all the BS and hype about how precisely the factory aims these lights but I don't buy it. I aim my lights well below where they annoy other drivers and have DOUBLED the effective range of them over the factory adjustment. Call me cynical, but I think the factory aims these things drastically low because they figure that most of the targeted audience for premium cars with xenon headlights live in an urban setting with abundant streetlights where headlights are just to let other drivers see your car at night. Proper headlight aim is the best "free mod" you can do.
Rawhyde
Rawhyde, I have the standard lights on my 09. I found the hex screw you mention, but I have only one per light. I guess I only have up and down, which is fine as that is the problem, but am I missing where the other one is?
Jim
Old Apr 26, 2009 | 10:03 PM
  #53
Penelope_the_MINI's Avatar
Penelope_the_MINI
Originally Posted by MiniBertile
If you've got auto adjusting lights, it might be worth a quick look at the sensor on the left front control arm.
I forgot to reconnect mine once and when nightfall came the lights were aimed nearly straight down and I couldn't see anything.
Where on the left front control arm is this sensor? and what does it look like? I just had my Clutch replaced and I don't think the guy re-connected mine beings how it all worked great before, and the night after I had my clutch replaced they didn't raise up.
P.S. Clutchmasters Stage IV flywheel/clutch kit = AMAZING!!!
Old Apr 27, 2009 | 09:46 AM
  #54
Penelope_the_MINI
bump!
Old Aug 4, 2009 | 03:01 PM
  #55
djafactor's Avatar
djafactor
Do the adjustment screws adjust both the high and low beams together? My MINI just got dinged at provincial inspection for the highbeams being too high?
thanks
Amit
Old Aug 4, 2009 | 03:43 PM
  #56
Goodwood's Avatar
Goodwood
In my car they do...
'03 MCS
Old Feb 3, 2011 | 06:16 PM
  #57
J_Westy's Avatar
J_Westy
Originally Posted by A-W
I hate to bump old threads, but does anybody know if the high beams can be adjusted seperately? My lows are great, my highs point straight into the ground.
Bumping an old thread, but I came across this question when researching how to adjust the xenons in my '05 last night.
When I went to replace my H7 highbeam bulbs today, I found one of the old bulbs not quite clipped in all the way. The three hokie tabs that hold the bulb in don't seem the easiest to engage, so I'll be this could have happened to the person from this 2 year old post.... just wanted to add this tidbit for future searches.
BTW, I put in Philips E-treme Power +80 bulbs. They have truly impressive output for a legal bulb. Highly recommended.
http://www.amazon.com/Philips-X-trem...6785639&sr=8-1
Old Feb 10, 2011 | 02:04 PM
  #58
Project_2501's Avatar
Project_2501
I just properly aligned my headlights using the guide available at Daniel Stern (as I have with all prior cars) and it made a tremendous difference for the short little trip I went on last night.
I had to mess with both left/right and up/down.
Old Apr 10, 2011 | 01:11 PM
  #59
Goop's Avatar
Goop
I know this is an old thread, but I see no mention of adjusting the Day Time Running Lights. My xenon low beam and high beam adjustment is fine. I'm assuming the two adjustment screws are for the the low & high beam xenon lights. What about the DTRL? The left one just doesn't look correct.
Kevdog
Electrical
17
Jun 4, 2016 02:20 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
theateist
Sep 16, 2015 07:22 AM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
tylewis
Sep 6, 2015 07:36 PM
