R50/53 MINI on jack stands?
Any tips for jacking the car on asphalt? I've read about putting plywood underneath, but in the worst situation you'll have wood under that jack and under each jack stand (5 pieces total). Is this the only alternative? If so, how thick should the wood be? Are there any jack stand designs that spread the weight out in a manner that they could be used alone on asphalt?
Couldn't you use 1/2" or 3/4" plywood? You're worried about them sinking in right? Never thought of that one; what are you going to do if you get a flat on the asphalt highway in 100 deg temps? MBE carry a square piece of plywood in the boot?
Jack Point
The picture of the underside of my car shows the jack point is outboard of the seam and is the (I think) prefered surface to jack the car on my Mini (06 non s 08/06 production).
I will use a 2x4 block just far enough away to allow a jack stand to be slid in when it is raised. I also think a 2x4 will distrubute some force over 4 feet, but will only prevent deflection over a foot or so (6" each side). You can bend a 4' section of 2x4 with your own weight.
However, Pep Boys does carry the red Torin al jack stands. That's where I bought 'em a few months ago for $50 a pair. I was in the store recently and I only saw them bundled with the al jack (HF quality I hear). There's a picture on NAM showing Msfitstoy's Mini on jackstands. They look like torin jackstands to me.
If you can spring for the AC Hydraulics, get the 3000N-GS1, as they come with a flat top with a rubber pad.
So I was in the same boat, looking for jack stands that did not leave their mark behind on the asphalt. I was able to get the torins at a good price. But you know you want the AC's!!!!
Interesting how similar the Torins and Blue Flames look the same yet the price is way different. Anyway, thanks for the links. I was told to put wood under the jack too. That's too much wood
so jack stands like these are just what I need. I'll be checking out Pep Boys and squelching my urge for the ACs
The Blue-Point Alumstands are made by an outside vendor possibly makers of other company's versions of the same thing. And yes unfortunately there will be a premium price on the Snap-on pieces. I'd still by em though they are really short nice for the MINI.
OK - I happened to be doing this today, so I took some pics and posted the step-by-step on my blog.
At the risk of hijacking the thread, how long did your wheel washing/scrubbing/polishing/waxing/eatingOffThem take? You do this very 5k miles? Impressive.
I never thought of scrubbing out the wheel wells. Probably a great idea up in in WI to get rid of all the winter salt.
-Ed
It took a little while - I think I spent about 2 hours on just wheels yesterday... but by taking the time to do that, now they'll be easy to clean until the next rotation - I just give them a spritz of Slick and wipe down with a microfiber every few days between washes, and at wash time all the crud comes off easily front and back with a quick wipe of a wheel brush. WheelShield rocks.
Finally getting around to a follow up post. I did get the Torin jack stands. They are very nice and did not leave marks on my blacktop drive way. The one thing that is worth knowing is that they do not line up very well with the jacking points on the MCS. The tops of the stands are too narrow. The edges of the jack points don't fit on the flat part of the stands, but on the raised edges. Do to that, I wouldn't recommend them for us MINI owners unless you have an alternate idea of where to place them or alternate jacking pucks that are more narrow than stock.
Thanks! They are the Dinan 3 Piece Forged 18 inch wheels, equal width all around. Equal tire sizes all around 225/35 18.
According to the shop manual (TIS disk from ebay) there are jacking points near the centre at the front "Side of front axle subframe" (shows the same on R53 or R56). I've been looking for those, but can't find anything obvious. Anyone know exactly where they, or have pictures? This is what the manual says:
My theory is you could get jack up the usual front jack point, and get a stand under the rear jacking point. Then jack up one of the centre points and get a stand under the front jacking point. I'm a little wary of the 2x4 method.
