R50/53 Help - Rattle is driving me nuts
Old Dec 3, 2006 | 08:43 AM
Larry Clemens's Avatar
Larry Clemens
I have noticed a rattle that seems to be coming from the front driver's side of the car when going slowly over rough roads, manhole covers, etc. It sounds like metal objects rattling in a toolbox. I have a Detroit Tuned BBK, Koni FSD shocks, H-sport springs and PIAA driving lights. All the suspension units are tight, nothing is loose under the bonnet, and I can't elicit any rattle noise from the front wheel when hitting it with a mallet. I am starting to suspect the PIAA light brackets. Any ideas
Old Dec 19, 2006 | 12:46 AM
GrFa's Avatar
GrFa
Did you have a reduction pulley installed/engine jacked up? The heat shield that goes behind the exhaust manifold and down through the transmission tunnel where the coolant expansion tank mounts was loose on my car and made a similar sound after getting wacked around from a pulley install. I just kind of bent it back into place. Check the other heatshielding in the area/underneath the car as well. Its quite flimsy.
Old Dec 19, 2006 | 03:20 AM
Larry Clemens
I found the rattle. It was the front brake pads chattering inside the BBK front calipers.
Old Dec 19, 2006 | 05:13 AM
k_h_d's Avatar
k_h_d
What did you do to resolve it?
Old Dec 19, 2006 | 04:00 PM
Larry Clemens
Matt at Central Coast Coopers removed the front pads and applied some silicone-like product to the metal surfaces. The product was called something like Anti-brake squeal. No more noise!!
sevin
May 2, 2026 06:11 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
iclancy82
Aug 11, 2015 09:35 AM
