R50/53 Randy got a question???
Old Mar 11, 2003 | 06:11 PM
Nobull60's Avatar
Nobull60
Can you photo and post the jack points for a floor jack and jack stand placements. I do not like the jack supplied for the car and using Rhino ramps has its limitations. thanks
Old Mar 11, 2003 | 06:24 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Nobull,
The quick answer is there aren't any good points on the MINI unless you have a lift.
That said, take a look at the brake bleed how-to - I think it's in there as well as the oil change how-to.
The way I do it is to use the chassis in the front with a hockey puck, then jack up the entire side. I then put the stands under the factory points, making sure you haven't got any factory defects - the jack point won't be stable at all if the "pin" hasn't been inserted all the way into the chassis.
Let me know if you still have questions - hope that helps!
Randy
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
Carwash
Sep 15, 2015 02:02 AM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
