R50/53 Double clutching and a new clutch
Old May 3, 2006 | 06:14 PM
  #51
kapps's Avatar
kapps
Originally Posted by Funk_Flex
Anyone else having trouble with the MINI's floor hinged gas pedal? I used to heel toe like a pro when I had a Miata. But I can't seem to do it in the MINI.
With my feet positioned as in the pic above, I just can't blip the throttle. I guess it's b/c most of the pedal travel is in the top portion of the pedal. Also, the drive-by-wire throttle doesn't make things easier
It's much easier on the MINI to just roll the outer edge of the ball of your foot onto the gas pedal. It's not perfect technique but you just don't get the control if you use your heel. And I definitely agree the drive by wire throttle is a pain.
Old May 3, 2006 | 06:48 PM
  #52
Andrewsky's Avatar
Andrewsky
You know, the real problem with double-clutching is that the rpms drop too fast between gears. You have to be very, very quick with your feet. It's also very hard to do it quitely because to do it quickly one has to slam the clutch pedal against the "firewall."
Old May 3, 2006 | 07:57 PM
  #53
lexlow's Avatar
lexlow
Originally Posted by Andrewsky
I thought powershifting is when you keep the gas floored while you change gears (using the clutch).
It is!
Sep 23, 2015 12:52 PM
Sep 23, 2015 12:39 PM
Sep 22, 2015 02:05 PM
Sc00terbum
Sep 11, 2015 09:07 AM
Filmy
Sep 6, 2015 10:06 PM
