R50/53 Things You Didn't Know About Your MINI
Originally Posted by cooper girl
Here's one someone told me about: To be a trickster, turn the rear window washer jet around (they said it can be done with a screwdriver) and when you spray to clean, the stream will spray the person behind you.
Sounds like an item for the Road Rage Thread
Originally Posted by WingNut
Here's a little tip:
Should you ever need a jump-start, you need to let the battery "charge" about five minutes before you attempt to start it. If you don't everything will flash on your dash and you'll hear the scary clicking noise (and it won't start). This goes for jump kits, another car, and tow trucks.
Also once you get the MINI jump-started turn on everything before removing the cables. This is supposed to prevent a possible overload.
Originally Posted by blalor
The removal process is the same for your mirror, Johnna. I forget which direction, but it does remove the same way. There's some wire which tethers it to the roof of the car, however; I think you need a torx bit to disassemble the bracket and free up the wire. Once you've done that once, tho, you can just pop it off when you're autocrossing.
While looking at the mirror, I noticed the crying clown face just above it.
Originally Posted by become1
speaking of EZpass, if you have the double sunroof you can stash/stick your transponder to the glass in the nook where the screen latches on the rear sunroof.
no reason to have an ugly transponder on your windshield!
Originally Posted by shankrabbit
yeah... you don't have one of those?
like this:
like this:
I'd crash if I had one of those!
The sad clown face referred to, I think, is the "face" created by the new multi light pod/advanced airbag lamp design on the 05 up cars.
PS: Never heard of the CHP ticketing with regards to the Fastrak location before?
like this:
like this:
I'm talking about the light controls above the rearview mirror (2005 others??). The control buttons are eyebrows. The lights are eyes. The orange ambiant lights are tears and the passenger airgbag light is the mouth.
Another startup suggestion...
Since I have the chrono pak, I can see that my oil pressure is much higher when starting cold, then it eventually tapers off when the engine warms up. Whether this is because of viscosity or secondary oil pump I do not know. Because of this, I always allow the engine to warm up for a minute at least (this also gets the stumbling out of the way) before I drive. I also NEVER get on it before the engine reaches operating temperature. I feel that the longevity of my engine is worth the few extra minutes each morning.
Did you know that because of their torsional rigidity, if you jack up one wheel another wheel lifts too (depending on where you put the jack)?
Originally Posted by Tarzan
Here in the USA, this isn't included with the car. In the UK, as I understand it, the car is equipped with a first-aid kit, fire extinguisher, traffic triangles wheel chocks, and a green reflective vest...anyone care to confirm all of this?
Originally Posted by justaguyinvegas
I can see that my oil pressure is much higher when starting cold, then it eventually tapers off when the engine warms up. Whether this is because of viscosity...
Steve
I noticed that the low fuel hash-mark is orange (when the light indicator is not lit up red) and the highest level of fuel hash-mark is dark grey.....and the high temperature hash-mark is orange and the lowest temperature hash-mark is dark grey...I never noticed that before on my 04 MC with center speedo....I was checking out the previous post about waiting for the the low fuel indicator light to shut off when turn the key prior to actually cranking the engine
Originally Posted by Funk_Flex
I noticed that the tool kit has a provision for.... Oops, if I post it then it would defeat the purpose
Send me a PM if you wanna know
I'll let you know if I see any provisions, as soon as I get back,
Tatt
Originally Posted by tattman23
Slow day, so I'm going to go outside and look for provisions in my tool kit...
Tatt
Tatt
. On the outside, I never before saw what looks like a hole about the size of a tire lug (?)...
Other than that, no provisions found,
Tatt
Originally Posted by Jersey_Bill
I discovered something I didn't know this morning driving my MINI to the train station for the very first time - you don't dare throw your computer backpack on the front seat next to you without buckling it in !!!
The seatbelt alarm went off and just refused to shut up until I threw the backpack in the back seat. Seriously, designing the front seat sensor for 40 lb. people?????
Bill
Bill
I didnt see these two listed...
1) The wipers (I have nonrain sensing) will adjust with the speed of the car. for instance if you have them on regular speed and pull up to a stop light they will slow down, and then return to their normal speed once you start moving again. Note - I think this is true but I could just be seeing things...
2) The gas cap on the MINI S can be held in the gas cover when it is open and you are re-fueling.
I wanted to see how the headlight washers work, so when I got home, I kept the engine running, lights on, got out, flipped on the washer. Only the windshield worked, not the headlight. What's with that?
Originally Posted by iriemanhq
Great thread! Lots of stuff I'll have to check out *if it ever stops raining!* Anyway, I was hoping I would find out what goes in the plug(s) on the e-brake?
thanks!
//oo\\
thanks!
//oo\\
Found this one today
In the rear compartment, drivers side (tool kit location)...
Look in and up, there is an emergency fuel door opening handle.
This could be useful info if the lock solenoid failed and left you unable to re-fuel.
Originally Posted by theresa83
is that hole/tear in the leather of your e-brake? i had the same thing and i had the dealership replace it for new one. thank goodness for warranty!
//oo\\
fluid in the headlight washer reservoir? The reservoir on the passenger's side
is for the windshield and rear glass. The reservoir on the driver's side is for
the headlight washers.
