R50/53 Why is your Mini so fast ......
Old Jun 17, 2005 | 03:02 PM
  #51
ZenAudio's Avatar
ZenAudio
Originally Posted by C4
The '05 MCS 6-speed manual, doesn't need a pulley!
(Pulleys are to make up for the extremely tall 1st gear on the '02-04s)
Drive a '05, you will thank me!
I still yearn for more off the line with the '05. The car is perfectly balanced in the twisties, however, where I quite fortuitously, do most of my motoring
Would a 15% pulley add off the line ooomph without affecting the overall balance? If so, when is the next pulley party!!!!
Mike
Old Jun 17, 2005 | 03:56 PM
  #52
mikem53's Avatar
mikem53
Mike
I plan on doing the 15 pulley. The JCW kit uses about the same ratio so it seems to be a proven mod. You will get about 4 psi more of boost, which is a good thing...
It seems the stock setup runs a bit rich, so you will be OK with the 15. Everything else seems to be within "safe" operating spec for the extra boost. Good luck..
Old Jun 17, 2005 | 05:27 PM
  #53
Sebaflex's Avatar
Sebaflex
while my 05 MCS is not what i would call "Fast" .... it has definately held its own against what i thought were faster cars...
I've race several of my friends cars including a IS300, a Modded RSX-S, a Stock WRX, and a 201hp GTi VR6 and have kept up or even won them on some ocassions... not bad for 168hp..
but i could agree with all of you here, where the MINI shines is in the Handling department... my friend with a 350z has a hard time keeping up with me in the twisties..and he's a better driver than me
Old Jun 17, 2005 | 05:32 PM
  #54
xsmini's Avatar
xsmini
Becase its LY/W Oh, no the BRG's are the fast ones:smile: .
Actually for a car in its price range it (to me) is pretty fast. But more importantly ist quick and nimble
Nik
Old Jun 17, 2005 | 06:06 PM
  #55
Yellow_mini's Avatar
Yellow_mini
Mine is fast because I keep it clean, DUH everyone knows clean Minis go faster
Old Jun 17, 2005 | 10:20 PM
  #56
lotsie's Avatar
lotsie
Using the HP ya got at the right times, helps
Old Jun 17, 2005 | 11:18 PM
  #57
bluezone's Avatar
bluezone
Originally Posted by OctaneGuy
Hahaha MINIClo thanks!!!
Bluezone, the MC and MCS are very different cars when it comes to power. The MC requires more work on the gear shifter to keep it in the power band. When I test drove the MC, I didn't realize I wasn't driving it like it was meant to, that is I shifted at 2,500 and 3,000 rpm, which was about right when I had my Acura Integra. Acceleration was decent, but not quick.
These days, I shift at 6,700 rpm when I want to move fast, or from day to day driving, between 4,000- 6,000 rpm. I like to cruise at 4,500-5,000 rpm on the freeway in 3rd gear because stepping on the gas makes the MINI accelerate quickly!
The last time I drove with a bunch of MINIs, I kept up with the MCS's by downshifting a lot---when they punched the accelerator and took off, I downshifted and shifted late to maximize HP. So while it was less effort for the MCS's to go fast, I hung tight on their tails in my MC. This would be true even without any mods, but the intake and exhaust make it purr, and the ECU mod was probably the biggest bang for the buck.
Guilty as charged. Yes, I was shifting at 2000 and 3000 RPM's . I actually thought that letting the RPM's go past 4000 or 5000 would cause serious transmission and engine problems. I tried it for the first time today, letting Mini get to around 5000 to 6000 RPM's before I shifted. Definitely made a difference...Mini was much quicker on the draw.
Still want more speed but I'd like to keep warranty if possible. I'm guessing a reduction pulley will void but can someone tell me if an Intake, Exhaust and ECU mod void warranty? According to my dealers, they can't do any MOD work at all . Therefore they literally had no answer.
Old Jun 18, 2005 | 01:05 AM
  #58
1nf3rn0's Avatar
1nf3rn0
If you do an exhaust/intake mod, the dealer will only void the part that you changed (dont hold me to this, but most dealers will). If you do a pulley, you void everything under your hood. Trust me, the sound from a nice exhaust and m7 AGS will do wonders (please lets not start the ags debacle again...), both in sound and speed. Wait till your waranty is up and then do the 15% pulley. You will enjoy it
Old Jun 18, 2005 | 11:03 PM
  #59
Califzeph's Avatar
Califzeph
Today at a stop light, I noticed a Subaru pull up behind me. On green, I quickly sped from the limit line to a brisk 80 MPH, red lining all the way through the gears. The Subaru kept up with me nicely.
Old Jun 19, 2005 | 09:35 PM
  #60
minihoopercooper's Avatar
minihoopercooper
why my mini is so fast
my lead foot! when i say go - he goes and leaves everyone else behind - i drive a mc with no mods!
jeremy_reyes94
Sep 6, 2019 07:53 AM
Cereall
Sep 5, 2019 06:05 PM
Dashdog
Aug 10, 2015 06:17 AM
