R50/53 unsprung weight = free HP?
My question is: if it takes 15 Hp to move 100 lbs. in a car then how much can I unleash by reducing 90 lbs. of unsprung weight from the wheels and tires?
Another perspective on this. Some folks install a lighter flywheel so the engine will be more responsive to throttle. Taking off 15 lbs per wheel/tire per corner is equivalent to going to a 60-lb lighter flywheel.
Note that the mass distribution of wheel/tire combo have very high concentration at the circumference. This make a very efficient flywheel in storing kinetic energy. Note that the analogy of the engine flywheel have to keep in perspective as the transmission and differential gear ratio changes the engine torque multiplier.
BTW. I hauled down my 14" Miata wheel/tires from my garage attic and put the 16" MINI ones with RF up there. I was so shocked that the latter weight felt weighting twice as much.
Performance minded Miata owners figured out long time ago wheels and tires too big and too wide are all show no go.
There is an optimum size combo for the given vehicle hp, weight, chassis dynamics, and the intended goal. Please just don't ask me which it is.
Note that the mass distribution of wheel/tire combo have very high concentration at the circumference. This make a very efficient flywheel in storing kinetic energy. Note that the analogy of the engine flywheel have to keep in perspective as the transmission and differential gear ratio changes the engine torque multiplier.BTW. I hauled down my 14" Miata wheel/tires from my garage attic and put the 16" MINI ones with RF up there. I was so shocked that the latter weight felt weighting twice as much.
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
