R50/53 25K mile service
25K mile service
At approx 25K what service is it? Is it a Inspection 1 service? or Inspection 2?
Are they suppose to replace anything? Change any fluids besides the oil?
I know it says that Brake Fluid is suppose to be changed every 2 years... I'm at that now... but not really due for a service... can I go in and just do that and have them inspect my brakes?
WOW NO ONE knows my questions about 25K service?? Oh wells... I was hoping to gather some info before going to the dealer... but I guess I'll just have to go in and see waht they tell me and see if they are BSing me or not...
From the Bentley manual---->
undercar maintenance:
change oil and oil filter
Check transmission and differential for external leaks
change CVT fluid (auto transmission)
check CV joint boots for damage of leaks
visually check fuel tank, fuel lines and connections for leaks
check condition, position, and mounting of exhaust system,
visually check and adjust if necessary
check struts and shock absorbers for leaks
check front control arm bushings for damage or wear
check power steering system for leaks.
check power steering fluid level and adjust if necessary
check steering rack and tie rods for tightness
check condition of steering linkage and steering shaft joints
check overall thickness of front and rear brake pads using BMW
special tool. if replacement is necessary:
examine brade disc surface
clean brake pad contact points in calipers
grease wheel centering hubs
check thickness of parking brake linings only when replacing rear brake shoes (don't think this is right)
check operation of parking brake and adjust as necessary
check brake system connections and lines for leaks damage and incorrect positioning
check parking brake actuator. adjust if necessary
check all tire pressures (including spare if equipped) and correct if necessary
check condition of tires (outer tread surface) tread wear pattern.
in case of uneven wear perform alignment
inspect entire body according to terms of rust perforation limited warrantee. (must be performed at least every two years)
Engine compartment:
read out OBD II fault codes
check engine coolant system/heater hose connections for leaks
check coolant level and antifreeze protection level
add coolant as necessary
check air conditioner for operation
replace ventilation microfilter (reduce replacement interval in dusty conditions)
reset service interval display
Body/Electrical:
check battery state of charge
check operation of:
headlights, foglights, parking lights, back up lights, turn signals,
emergency flashers, stop lights license plate lights, interior lights,
glove compartment light, make up mirror lights, flashlight, engine
compartment light, trunk light.
check instrument panel, dashboard illumination
check warning and indicator lights, check control
check operation of horn, headlight dimmer and flasher switch
check wipers and windshield washer system
check aim of washer jets and adjust if necessary
check condition and function of seat belts
visually examine all airbag units for torn covers, obvious damage or
attachment of decals, decorations, or accessories
check central locking system
check operation and condition of door, engine hood, and rear hatch latches
check heater, air conditioner blower and rear window defogger operation
check operation of rear view mirrors
Road Test:
check braking performance, steering, heating and a/c operation
check manual transmission and clutch operation or auto trans operation
also....if it's been more than 2 years, the brake fluid gets replaced
Engine compartment:
Body/Electrical:
check operation of:
Road Test:
Hmmm... change the CVT fluid at 25K?
Hmmm... I see you got that information from the Bentley Service Manual. Is that the same as in the actual MINI Dealer Service Manual?
Reason I ask is because last month the dealer performed 25K service on my 2003 MINI CVT, and they did not change the CVT fluid. They did pretty much (at least they say they did!) everything on that list except change the CVT fluid.
The service advisor did say that on or after my 2 year anniversary owning the car (which is June 6) that I can make an appointment and they will change the brake fluid free of charge.
I'm wondering now -- is it OK to drive the car with 2-year old CVT fluid, should I go back in June and insist they replace the CVT fluid while they're changing the brake fluid anyway... thing is, they will probably want to see some documentation that states "change CVT fluid at 25K" but I do not have that documentation...is it printed in the MINI manual that came with the car?
Thanks much,
-boognish
Thanks much,
-boognish
Just checked with the CVT manufacturer...
Well, sort of. I found, and downloaded, the entire CVT Service Manual (actually it's more of a complete description of the ZF VT1F CVT gearbox) from MINI2.com. On page 10, it says "A refill of the transmission oil is necessary every 45,000km"
I believe 45,000 kilometers is equivalent to approximately 28,000 miles. So, I am going to print out this manual and bring it to the dealer in June (at which time I will have about 29,000 miles on the MINI) during the free brake fluid change. Hopefully they will also agree to change the CVT fluid, once they see what's printed in the manufacturer's manual.
Thanks,
-Boognish
Thanks,
-Boognish
Thanks cristo... I read all that in mini usa where it shows whats to be done at what service... I was interested in knowing if 25Kmiles was a inspection 1 or 2...
and seems like the answer is right here.
Thanks!
Originally Posted by OKeefe
at my 25k they documented 'level 1 service', changed oil and flushed brake system / changed fluid "because inspection showed it needed it"
no charge
Checkered Flag
no charge
Checkered Flag
gmonde
Sep 8, 2015 06:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
Powershift
Aug 16, 2015 05:14 PM
