R50/53 squeal when starting out
Old Mar 17, 2005 | 06:47 AM
seaniem's Avatar
seaniem
2002 cooper.
44,000 miles.
bought Mar 31, 2001.
so new problem. whenever i start the car, and start out of a space, there's a loud squeal from the engine bay. seems to be connected to the steering motor, as it's only after i've turned the wheel. it lasts maybe the first 5 seconds after starting the car, and doesn't resurface until the next time i start the car. has anyone else experienced this? any recommendations on a cure?
Old Mar 17, 2005 | 07:23 AM
camelpilot's Avatar
camelpilot
do you know what a loose fanbelt sounds like? Does it sound anything like that? Usually belts "squeel" if they are loose. If thats the case you need to take car to a specialist asap.
Old Mar 17, 2005 | 10:01 AM
brgfan's Avatar
brgfan
I've had power steering pumps make noise when they're low on fluid. You might check the level, just in case.
Old Mar 17, 2005 | 12:41 PM
JCW Driver's Avatar
JCW Driver
Your accessory belt may need a tensioning adjustment or replacement. Not unusual that it would be a loose and squeal when slippery and cold.
It could be something far more serious, so don't let it go..
iggi
18
Feb 9, 2026 01:00 AM
davidbeaver1
14
Nov 8, 2015 05:22 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
minimofo
Sep 9, 2015 10:29 AM
Steffen.Johnson
Aug 23, 2015 08:30 PM
