R50/53 ECU reprogram or service qustion
I have had my R53 layed up (2 mo.) to change out the supercharger, replace the radiator/water pump, all cooling lines. My question is do I need to reprogram ECU or just initiate the maintenance mode before starting it up.
Regards,
Keith
Regards,
Keith
@mcart5 Fuel pump would be easy to diagnose. Release the pressure from the fuel rail, crank the car a few times and see if the pressure returns. Furthermore after the pressure is relieved you should hear the pump running once you engage the key without even trying to crank the engine.
Do you have access to ISTA or INPA?
